# After beacon calibrate and save config klipper unable to recognise default
**URL:** <https://klipper.discourse.group/t/after-beacon-calibrate-and-save-config-klipper-unable-to-recognise-default/19360>\
**Created:** [October 12, 2024, 9:19pm UTC](https://klipper.discourse.group/t/after-beacon-calibrate-and-save-config-klipper-unable-to-recognise-default/19360 "2024-10-12T21:19:38Z")\
**Showing post:** 4
**Post date:** [October 14, 2024, 3:13am UTC](https://klipper.discourse.group/t/after-beacon-calibrate-and-save-config-klipper-unable-to-recognise-default/19360/4 "2024-10-14T03:13:20Z")
Please also the printer.cfg as a file! and not Copy & Paste.
At least use the `Preformatted Text` feature of the forum editor.
![Format](https://global.discourse-cdn.com/free1/uploads/klipper/original/2X/6/643ab9def96b03089cfb0c194628129fcc96b3f8.png)
The way you did it, the data is not usable at all.
BTW: You have 12 (!) config blocks. That can not work.
_[View the full topic](https://klipper.discourse.group/t/after-beacon-calibrate-and-save-config-klipper-unable-to-recognise-default/19360)._
