# Bed temperature on change filament in gcode macro global var
**URL:** <https://klipper.discourse.group/t/bed-temperature-on-change-filament-in-gcode-macro-global-var/18221>\
**Created:** [August 11, 2024, 2:44pm UTC](https://klipper.discourse.group/t/bed-temperature-on-change-filament-in-gcode-macro-global-var/18221 "2024-08-11T14:44:42Z")\
**Showing post:** 11
**Post date:** [August 12, 2024, 5:45pm UTC](https://klipper.discourse.group/t/bed-temperature-on-change-filament-in-gcode-macro-global-var/18221/11 "2024-08-12T17:45:09Z")
See [Using START\_PRINT and END\_PRINT Macros](https://klipper.discourse.group/t/using-start-print-and-end-print-macros/15459) how such macros SHOULD work.
I do not know what Sovol is doing here or intends to do. In doubt, it might be best to contact them directly.
Another approach would be to get rid of this macro hell and use only stuff you need.
_[View the full topic](https://klipper.discourse.group/t/bed-temperature-on-change-filament-in-gcode-macro-global-var/18221)._
