Printer Model: Anycubic Chiron
MCU / Printerboard: Trigorilla ( ATMEGA2560 )
Host / SBC: RPI Zero 2W
klippy.log (184.9 KB)
Hello Guys, I have a problem with connection via USB from RPI Zero 2W to Trigorilla (ATMEGA2560) I check everything several times. Connection itself works I got information at RPI about USB in /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0
The same value has been setup in Printer.cfg MCU section
Only one Concern when I prepare makeconfig there is no USB ( Iām not sure why or if it is normal ) only UART0-3 available here.
Upload proces goes normal using AvrDude method, any way no connection.
All my ideas what it can be are over - please try to help.
Thanks in Advance
