E3D REVO Hotend Help
Printer Model: CR10-S
MCU / Printerboard:
Host / SBC Raspberry Pi w/ Klipper Screen
Hello! I am upgrading to a Micro Swiss NG REVO Direct Drive Extruder, and after I got it installed and went to see if the hot end would work, it wouldn’t start to heat up. I wired it using the provided “Butt Splice Connectors” that came with the Extruder, and I am confident in those connections as I can see the “Blades” in the connectors go into the wires. Does anyone have any experience with a REVO Hotend and Klipper? I’m not sure if the heater pin would be different on this Hotend, and if it is, how to find the correct pin name.
Advice appreciated!
I clamped down on the Butt Connectors more and now the hotend heats like normal.
