Feature request: Silent probe
Hi Team,
I’m in the process of building out a mesh validation and probe deviation benchmark extension.
I’ve noticed that the manual probe can get quite noisy
Any possibility of adding a QUIET=1 variable for the Probe GCode command?
you could achieve the same with a simple macro.
it being quiet comes down to your printer. simply add the required probe parameters that make it quiet to that command. the probing will then happen with those quiet parameters.
