Internal error during ready callback: Unable to save variable
Printer Model: Ender 3 V2 Neo
MCU / Printerboard: BTT SKR Pico
Host / SBC: RPi 4B+ 1GB
klippy.log (1.3 MB)
I just updated to the latest Klipper version, and suddenly started getting this error “Internal error during ready callback: Unable to save variable”. I have looked at Klippy.log, and found this:
  File "/home/AdamDrefs/klipper/klippy/extras/save_variables.py", line 59, in cmd_SAVE_VARIABLE
    self.executor.submit(write_out)
  File "/home/AdamDrefs/klipper/klippy/extras/aio_executor.py", line 55, in submit
    result, exc = completion.wait()
  File "/home/AdamDrefs/klipper/klippy/reactor.py", line 38, in wait
    self.reactor.pause(waketime)
  File "/home/AdamDrefs/klipper/klippy/reactor.py", line 240, in pause
    self.verify_can_pause()
  File "/home/AdamDrefs/klipper/klippy/reactor.py", line 275, in verify_can_pause
    raise ReactorError("Internal error - reactor pause disabled")
reactor.ReactorError: Internal error - reactor pause disabled
Unhandled exception during ready callback
  File "/home/AdamDrefs/klipper/klippy/klippy.py", line 165, in _connect
    cb()
  File "/home/AdamDrefs/klipper/klippy/extras/mmu/mmu.py", line 949, in handle_ready
    self._load_persisted_state()
  File "/home/AdamDrefs/klipper/klippy/extras/mmu/mmu.py", line 1232, in _load_persisted_state
    self._set_gate_selected(gate_selected)
  File "/home/AdamDrefs/klipper/klippy/extras/mmu/mmu.py", line 6468, in _set_gate_selected
    self.save_variable(self.VARS_MMU_GATE_SELECTED, self.gate_selected, write=True)
  File "/home/AdamDrefs/klipper/klippy/extras/mmu/mmu.py", line 3893, in save_variable
    self.write_variables()
  File "/home/AdamDrefs/klipper/klippy/extras/mmu/mmu.py", line 3903, in write_variables
    self.gcode.run_script_from_command("SAVE_VARIABLE VARIABLE=%s VALUE=%d" % (self.VARS_MMU_REVISION, mmu_vars_revision))
  File "/home/AdamDrefs/klipper/klippy/gcode.py", line 238, in run_script_from_command
    self._process_commands(script.split('\n'), need_ack=False)
  File "/home/AdamDrefs/klipper/klippy/gcode.py", line 223, in _process_commands
    handler(gcmd)
  File "/home/AdamDrefs/klipper/klippy/gcode.py", line 151, in <lambda>
    func = lambda params: origfunc(self._get_extended_params(params))
  File "/home/AdamDrefs/klipper/klippy/extras/save_variables.py", line 63, in cmd_SAVE_VARIABLE
    raise gcmd.error(msg)
gcode.CommandError: Unable to save variable
Transition to shutdown state: Internal error during ready callback: Unable to save variable
I can tell where the error is coming from, but am unsure what to do about it. Any recommendations?
Weba @AdamD !
From what version?
And that is?
Ah, it is HH, so:
-Timofey
Got it! Will try what is recommended in that GitHub posts. Thanks!
Can confirm, rolling klipper back to df1a8cd8 fixed the problem. Thanks for pointing me in the right direction!
