This is completely depends on your point of view. On CoreXY where we limit tool head motion, but not the motor, motors can go higher up to sqrt(2) = 1.41.
I can agree on the point, like if you can’t go that speed - do not use it. 500-700 mm/s is still a pretty high limit.
So, it is practical in the sense that you can encounter it. Calculations are provided below.
Yes, but it is for TMC drivers with step-on edge enabled.
There are small modifications needed to test the general pulse code.
invert_step=0 step_pulse_ticks=44
General widespread gt2 with 20 teeth pulley, will give you 40 mm per rotation.
Then you work with your servos and try to overcome servo-specific issues (like salmon skin, lags & etc), crank up resolution, and get “Stepper too far in past”, because you tried to move the toolhead too fast, like 1000 mm/s mentioned above.
Got confused, checked benchmarks, did calculations, realized something was off, and you didn’t get close to theoretical board limits.
This is where I come into play because I got confused too, and start to dig, into what causes that and what can be done with that. (like speedup stepper code & to speedup MCU)
My mistake. Got it.
This is where I can’t agree. I don’t think this is the right topic to argue about printing speeds, in the sense like “This is practical and this is not, because I think so”.
If there is a will to argue about that in any sense, I can suggest moving to the general category.
For the current 3d printing epoch running higher than 200mm/s is a general recommendation because it allows us to completely avoid issues with VFA and motor resonances because they mostly happen at speeds below that, but I should notice, that it makes sense only for steppers.
Just as a personal example, I’m printing strongly faster > 200mm/s, up to 500 mm/s, with a travel speed of 1000 mm/s. It is totally normal and works normally on my pretty heavy/large 400 Ratrig. I like 0.1-layer thickness, nice overhangs, the perfect surface at that speed, and large prints. I like that, and can suggest anyone to try if your situation allows that.
So, I suggest avoiding arguing in that sense, there is obviously someone who will say 30mm/s is fine for everyone. The same is true for the other side of the spectrum.
From a practical perspective, we know there are hot ends with high flow capacity like >50 mm^3/s. It is pretty easy to use 0.1 layers, whereas, with a 0.4 nozzle, you get 50 / 0.4 / 0.1 = 1250 mm/s. (Mine is ~25mm^3/s btw).
So, I think 1000 mm/s is a pretty reasonable limit if we want to define one.
Hope it helps to understand what I’m talking about.
