Klipper-Ironing-Mid-Print
Klipper Ironing Mid-Print
Schedule per-object ironing on remaining top layers while a print is running — without editing gcode or touching PRINT_START / PRINT_END.
Built for Klipper + Moonraker + Mainsail, with OrcaSlicer (or any slicer that emits labeled objects). Pick the target object on a bed map (same layout as Exclude Objects), not from a text list.
