Hello smart people. I had a (kind of) working Ender 3 Max Neo modified with the creality sprite pro extruder. When it was sort of working, it was using an even cheaper Chinese breakout board on the extruder rather than the official creality one. Upon finally buying an official creality one, I installed it and the extruder and bet temps were perfectly fine. However, my hand brushed against the usb cord connecting my printer to my pi, and pulled it out. The cord seems to be doing just fine, and I have the same issue with another cord: the printer is reporting very definitely incorrect temps on BOTH the extruder and bed. It’s saying the extruder is at 77 degrees and the bed at 180 something. This is very incorrect, as both are indeed cool to the touch. Now, the weird part: I’m looking at the temps on fluidd, I unplug the extruder thermistor connector, still reporting 77 degrees. Same with the bed. At this point, I’m getting ready to give up on this printer even though I’ve put so many hours of service, repairs, and mods into it along with many hundreds of dollars more than I bought it for.
When you say your hand brushed past the cable and knocked it out, did it come out cleanly or did it partially come out at first and then come out? I’m just wondering if there was any arcing occurred on the power pins and pulled too much current through something.
After saying that maybe the cable coming out just coincided with the problem you’re seeing and wasn’t what caused the issue. Have you tried the other tool board again (the one you say sort of worked before) to try and isolate the problem?
If the old tool board works & reports temps correctly, the problem will be with the new tool board.
Your log does show where you unplugged each of the thermistors. Why it doesn’t show in the web UI I cannot say. But both ADCs are functional to some extent.
The only thing the 2 thermistor circuits have in common is the 3.3v power rail.
I’m 95% sure your mainboard is toast. It would be possible to wire the thermistors to GPIO pins on the RPi. You’d need a pair of 4.7k ohm pull up resistors.
Cord came out really easily since the little prongs in the microusb end were already broken. I tried with another usb cable, and found the same problems. I do think it was a coincidence with the cable thing though. I measured the resistance across the thermistor pins on the mainboard and got ~2500 ohms for where the hotend thermistor would go and ~3 ohms for where the bed thermistor would go. I think the board may have just finally given its last temps.
First, thank you for taking time out of your day to help a random dude on the internet with his printer. Second, your thoughts about the mainboard being (partially) fried are incredibly reassuring of my sanity. After I made the original post, I took the whole mainboard out and visually inspected the whole thing for any damage or defects, but couldn’t see any. I think this isn’t something that could be repaired by someone of my expertise. The thing you said about wiring the thermistor straight to the pi gives me some hope that this won’t be insanely expensive, so I’ll look into that.
So I set up a pi pico as a secondary mcu, then wired in and defined the thermistors (and 10k pullup resistors). I’ve been working with this for a while and yes, those pins now respond to changes in the thermistor wiring ( like shorting or disconnecting ).I’m stumped as to why it’s still reporting crazy incorrect temps though. extruder temp is atleast decently stable, but the bed is wild.
Klipper’s volts to temp conversion is based on a 4.7k pull up.
You CAN define a 10k but you’ll gain low temp resolution and LOOSE high temp resolution. Your best choice is to source 2 resistors of 4.7k with a 1% (or better) tolerance spec.
Earlier, i tried a potentiometer set to 4.7k in place of the 10k, but still got some funky temps. I think there’s some other issue happening at the same time, since the 10k’s should at least produce a reasonable temperature when defined. I’m stuck here and maybe considering buying a new mainboard.
After a few hours of trying tons of stuff, I decided it was time. I’ve spent more than $40 worth of my time on this, and rather than fall into the sunk cost fallacy, I have a $40 v4.2.7 mainboard arriving Tuesday. My family will thank me for the noise reduction anyways. Thank you for trying to help me through these issues, and taking time out of your life to analyze my problems.
Best regards,
The only being on this earth who has a klipperized direct drive soon-to-be-multicolor Ender 3 Max Neo
