LPC1768(Similar to smoothieboard) ,cannot be connected to the Klipper
You are not alone :sunglasses:
Yes, I tried. Still doesn’t work
Maybe this picture can provide some information
Sorry, My statement is wrong.There is no RS-232 on this board. What I want to say is NRZ serial
I mean CP2102 USB to UART Bridge on the board
I have tried USB and UART connections. I will provide wiring pictures later
I did make a mistake. When I noticed the information in the picture, I now successfully communicated with LPC1768.
uart [smoothieware.org]
You can now confirm that the LPC1768 board is working properly. I will try to refresh klipper again
[BUG] Pins error into BIQU BQ111-A4 board · Issue #18360 · MarlinFirmware/Marlin · GitHub might help with the pinning.
Here are also some useful informations https://www.aliexpress.com/item/32950619979.html
@Elect
Make sure you use a 12V power supply? Did you set J19 to VDD?
Are you talking about J14 on your board?
Smoothieboards https://smoothieware.org/smoothieboard are also using the USB controller on chip. Have a look at the schematics The Smoothie Project · GitHub.
The problem seems to be the CP2101. Usually LPC1768 µCs use a direct connection to the USB connector (pins 29 and 30 for LQFP100 packages) using the USB controller on chip. With this board, you are using an UART on LPC1768. That’s a different setup!
Only chance to get that board working: Is there an LPC board which uses UART to communicate with Klipper and is supported by Klipper. Maybe then, you may be able to construct a config to get it running.
This is gonna be tricky!
Good luck, hcet14
Edit: You may check, if there is a connection between pin 29 and 30 on LPC1768 and the USB connector. Maybe the USB connector is hooked up to LPC1768 and CP2101 in parallel. I have seen many funny 3D mainboard schematics!
I had the same problem and found that I had to use the kiauh tool to find the mcu number and copy it and paste to the [mcu] in the configeration file
