Printer Model: Voron Tridend 250
MCU / Printerboard: BTT Octoprint 1.1
Host / SBC: FriendlyElec NanoPC-T4
Summary of CAN Bus Stability Improvements (Before/After) During Long‑Duration Probe Accuracy Testing
Over the past days I’ve been troubleshooting rare but repeatable CAN‑bus communication hiccups during long‑duration PROBE_ACCURACY stress tests on my Voron Trident. These tests run continuously for about an hour while cycling bed and nozzle temperatures, which is a great way to expose timing‑sensitive issues in the CAN transport layer. For reference, I used the excellent probe stress‑test tooling from:GitHub - KiloQubit/probe_accuracy
Before the Change
Initially, my CAN interface was configured with:
pfifo_fastas the default qdisctxqueuelenset to 128, as commonly recommended in Klipper documentation
This setup worked “mostly fine,” but during extended probe‑accuracy loops I would eventually hit a CAN timeout or communication error. Reducing txqueuelen from 128 → 64 roughly doubled the runtime before failure, but still didn’t eliminate the issue. The errors were rare, but consistent enough to interfere with long‑term probe comparison testing.
Changes Applied
I made two adjustments to the CAN interface configuration:
Switched queue discipline from
pfifo_fasttofq_codel- This was done to reduce latency spikes and avoid occasional packet reordering under load.
Reduced
txqueuelenfrom 64 → 20- CAN frames are extremely small, and large queues only increase latency and jitter.
- A shorter queue forces more deterministic timing behavior.
These changes were applied via /etc/network/interfaces.d/can0 so they persist across reboots.
After the Change
With txqueuelen=20 and fq_codel active, I was able to complete a full 1‑hour probe‑accuracy stress test without any CAN communication errors. This is the first time the test has run to completion without a timeout. While I can’t yet say with certainty how much fq_codel contributed on its own, the combination of a shorter queue and a modern qdisc clearly improved stability in my setup.
This gives me a reliable baseline for comparing different Z‑probe hardware under identical conditions.
System Configuration
SBC: FriendlyElec NanoPC T4 (RK3399)
OS: debian-bookworm-core-arm64 (FriendlyElec Official)
Controller: BTT Octoprint 1.1 based on STM32F446ZET6 configured as CAN Bridge
Toolhead Controller: Mellow SHT36v3 based on RP2040
Z-Probe: FYSETC Super Pinda
klippy.zip (1.0 MB)
