Args: ['/home/pi/klipper/klippy/klippy.py', '/home/pi/printer_data/config/printer.cfg', '-l', '/home/pi/printer_data/logs/klippy.log', '-I', '/home/pi/printer_data/comms/klippy.serial', '-a', '/home/pi/printer_data/comms/klippy.sock']
Git version: 'v0.13.0-403-gb4c7cf4a3-dirty'
Untracked files: klippy/extras/autotune_tmc.py, klippy/extras/gcode_shell_command.py, klippy/extras/motor_constants.py
Branch: master
Remote: origin
Tracked URL: https://github.com/Klipper3d/klipper.git
CPU: 4 core ARMv7 Processor rev 4 (v7l)
Device: Raspberry Pi 3 Model B Plus Rev 1.3
Linux: Linux version 6.1.21-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP Mon Apr 3 17:20:52 BST 2023
Python: '3.9.2 (default, Mar 20 2025, 22:21:41) \n[GCC 10.2.1 20210110]'
The only logical explanation is if there are some weird SD card/system issues.
Or your system is configured in a way that it resets its state after the power cycle.
(and so any config changes will be reset too, after the power cycle).
I just looked at your klippy.log. You have a poop ton of macros and you’ve added additional python files to your installation.
I’m surprised that nobody here previously has pointed out that you have a “dirty” Klipper installation which is something that we normally don’t provide help with.
Have you gone back to the people supporting the autotune software and asked for help there?
Sorry, we are really only equipped to help with stock Klipper. Any modifications make or problems with the modifications are outside our area of expertise.
