I need some who is tech-savvy who can help me troubleshoot an issue with my 3D printer. I’m completely stuck.
The Printer: QIDI X-Max 3
The Error: !! No trigger on x after full movement
What’s happening:
The printer uses sensorless homing on the X-axis. When I try to home it, the toolhead moves smoothly but fails to register when it hits the left wall (or when resisted by hand), so it just times out and errors out.
What I’ve done so far:
Verified the carriage slides smoothly across the carbon rods by hand.
Completely replaced the motherboard with a brand-new one from QIDI, but the exact same error persists.
Because I’m not super comfortable messing with the wiring harness, inspecting the stepper motor pins, or diving deep into the configuration files on my own, I honestly don’t know whats the issue.
Its actually both, i usually get the x axis if the floor bed was already at the lowest level before selecting homing , all the axis are moving at the same time
I see you LOWERED driver_SGTHRS from 130 to 85. That makes it LESS sensitive to stalls.
Also lowering your current during homing reduces the back EMF spike that driver_SGTHRS senses. If your head is slamming too hard consider lowering the speed not the current.
