Printer Model: Voron 2.4
MCU / Printerboard: Octopus
Host / SBC Raspi 4
klippy.log: Not applicable - this is a code-reading finding, not an observed failure
quad_gantry_level: max_adjust only guards the positive direction
File: klippy/extras/quad_gantry_level.py, in probe_finalize()
Code:
z_ave = sum(z_height) / len(z_height)
z_adjust = []
for z in z_height:
z_adjust.append(z_ave - z)
adjust_max = max(z_adjust)
if adjust_max > self.max_adjust:
raise self.gcode.error("Aborting quad_gantry_level ...")
Problem:
z_adjust is computed as (z_ave - z_height) for each stepper, where z_ave is
the mean of z_height. The four values therefore always sum to exactly zero.
The guard tests only max(z_adjust), so it constrains the largest POSITIVE
adjustment and never examines the largest negative one.
Because the values sum to zero, for N=4 the most negative element is bounded
by -3 * max(z_adjust). The guard therefore permits a negative adjustment of
up to 3 * max_adjust.
Example (max_adjust = 10):
z_adjust = [-30.0, +10.0, +10.0, +10.0]
max(z_adjust) = 10.0 -> not > 10.0 -> passes
one gantry corner is then driven down 30 mm
Impact:
max_adjust is a safety limit intended to stop a bad probe result driving the
gantry into the bed. In the negative direction it under-protects by 3x. It
only bites when probing returns a wildly wrong value, which is exactly the
condition the guard exists for.
Suggested fix:
adjust_max = max(abs(z) for z in z_adjust)
or test max() and min() separately so the error message can report which
stepper and which direction.
