Printer Model: Voron Trident
Host / SBC: RPI5, mainsailos installed via pi flasher
klippy.log (3).txt.zip (3.7 MB)
Octopus in serial mode.
SHT36v2 toolhead using CAN through a Fysetc UCAN. Umbilical with a key-bak to keep it tensioned.
I’m getting consistent print failures with a variety of errors.
This log contains two - after the first I replaced the beacon cable. I believe that’s the root cause fixed there.
I’m going to replace the cable to the sht36v2 tonight.
The reason I’m posting is that there’s a strange cadence that concerns me: the ready_bytes spikes up every ten minutes-ish on both communication interfaces (CAN and serial) simultaneously. Is there something else that could be going on here beyond a cable failing?
