Turn on a led or activate a fan! and many other things, I don’t understand why I don’t see anything with gpiodetect from bash
Do you have some schematics?
Hi DarkPhoinix,
this one?
Yes but work only with python script and not found hardware on /dev/gpio … Klipper don’t work for execute external python script like led_on.py !Or not?
Without being the real authority to judge this:
- It seems that additional libraries are needed to control this board
- Klipper does not know these libraries nor can handle their functions
- As such I would consider a direct integration in the Klipper world currently as not implemented
- A work-around could be the shell command that allows you to call a shell or py script directly (unofficial / not supported extension). Big drawback is that this is only a one way thing, this means any output from such a script cannot be directly returned to Klipper (although this could be worked around as well)
I think anyone make a firmware for work on linux without GTK …
This might sound like a bit off the wall, but why don’t you use something like the EBB42:
https://www.aliexpress.com/item/1005004242943483.html
If you’re looking to run a fan (or two) as well as some LEDs (including neoPixels) it could be the perfect solution. It can be powered by a Raspberry Pi (or other computer running Klipper) through USB and run Klipper firmware so you can control or access devices using it like the controller or other boards in your printer from your printer.cfg or macros. Depending on where you live, it would probably cost the same as the RTK.gpio when you factor in shipping costs.
We had a discussion on a custom Klipper running USB expansion board, that is probably exactly what you want, some time ago here:
@aycaramba , can you give us a status update?
YES i like this!
I can install klipper in a STM32? and next i see gpiodetect work on bash? Right?
Unfortunately, I’m in the process of writing my engineering thesis, so I don’t have much time to work on this project. The PCB was ordered, however I had to put it aside for now.
You can flash klipper on stm32.
there are tutorials on the internet how to use klipper on bluepill, check it out. You will have to program the appropriate inputs/outputs. It will probably make it much easier to use the ready-made config, because some motherboards use the same STM processor. In this case, it’s probably enough to assign the appropriate i/o to what you want to use.
Remember that RTk.GPIO does not have any transistors, resistor dividers, dc-dc converters etc, so you’ll need to add them if necessary.
Yes, you can install klipper onto many STM32F (and G) MCUs, but I don’t believe you will be able to do it simply for the RTk.gpio as there doesn’t seem to be any publicly available schematics and the MCU (STM32F030C8T6) used with it isn’t in the list of devices for Klipper’s make menuconfig
This isn’t to say that it isn’t possible, but it will be a lot more work than doing it for the EBB42 or @aycaramba 's board.
I just saw that you asked @aycaramba about Klipper firmware for the RTK.gpio and I think you need to do some reading about how Klipper works.
Creating Klipper firmware is quite easy to do if the board you’re working with is supported in the Klipper make utility (both the EBB42 which uses the STM32F072 and @aycaramba 's board which uses the STM32F103, are devices that can have Klipper built for them using the standard tools). The STM32F030C8T6, used in the RTk.gpio isn’t available in the list of MCUs and doesn’t have a built in USB port, which means that there will be some software effort involved (others here can say whether the USB in Klipper is setup as a CDC port or uses some other protocol). Who ever does the work will also need to buy a device programmer for it (anywhere from $20-$50 USD, depending on the programmer).
When you have a board connected to Klipper, you won’t be able to use gpiodetect as the board and its peripherals are all local to Klipper and not accessible to the rPi system at large.
Probably not a lot of what you want to hear, but if you are looking for a few simple IO devices for Klipper, the EBB42 (or similar) board is probably your best bet.
root@klipper:/home/klipper# gpiodetect
gpiochip0 [INT33FC:00] (102 lines)
gpiochip1 [INT33FC:01] (28 lines)
gpiochip2 [INT33FC:02] (44 lines)
gpiochip3 [INT0002 Virtual GPIO] (3 lines)
root@klipper:/home/klipper# gpioinfo
gpiochip0 - 102 lines:
line 0: unnamed "volume_down" input active-low [used]
line 1: unnamed "volume_up" input active-low [used]
line 2: unnamed unused input active-high
line 3: unnamed unused input active-high
line 4: unnamed unused input active-high
line 5: unnamed unused input active-high
line 6: unnamed unused input active-high
line 7: unnamed unused input active-high
line 8: unnamed unused input active-high
line 9: unnamed unused input active-high
line 10: unnamed unused input active-high
line 11: unnamed unused input active-high
line 12: unnamed unused input active-high
line 13: unnamed unused input active-high
line 14: unnamed unused input active-high
line 15: unnamed unused input active-high
line 16: unnamed unused input active-high
line 17: unnamed unused input active-high
line 18: unnamed unused input active-high
line 19: unnamed unused input active-high
line 20: unnamed unused input active-high
line 21: unnamed unused input active-high
line 22: unnamed unused input active-high
line 23: unnamed unused input active-high
line 24: unnamed unused input active-high
line 25: unnamed unused input active-high
line 26: unnamed unused input active-high
line 27: unnamed unused input active-high
line 28: unnamed unused input active-high
line 29: unnamed unused input active-high
line 30: unnamed unused input active-high
line 31: unnamed unused input active-high
line 32: unnamed unused input active-high
line 33: unnamed unused input active-high
line 34: unnamed unused input active-high
line 35: unnamed unused input active-high
line 36: unnamed unused input active-high
line 37: unnamed unused input active-high
line 38: unnamed "80860F14:02" input active-low [used]
line 39: unnamed unused input active-high
line 40: unnamed "rotation_lock" input active-low [used]
line 41: unnamed unused input active-high
line 42: unnamed unused input active-high
line 43: unnamed unused input active-high
line 44: unnamed unused input active-high
line 45: unnamed unused input active-high
line 46: unnamed unused input active-high
line 47: unnamed unused input active-high
line 48: unnamed unused input active-high
line 49: unnamed unused input active-high
line 50: unnamed unused input active-high
line 51: unnamed unused input active-high
line 52: unnamed unused input active-high
line 53: unnamed unused input active-high
line 54: unnamed unused output active-high
line 55: unnamed unused input active-high
line 56: unnamed unused input active-high
line 57: unnamed unused input active-high
line 58: unnamed unused input active-high
line 59: unnamed unused input active-high
line 60: unnamed unused input active-high
line 61: unnamed unused input active-high
line 62: unnamed unused input active-high
line 63: unnamed unused input active-high
line 64: unnamed unused input active-high
line 65: unnamed unused input active-high
line 66: unnamed unused input active-high
line 67: unnamed unused input active-high
line 68: unnamed unused input active-high
line 69: unnamed unused input active-high
line 70: unnamed unused input active-high
line 71: unnamed unused input active-high
line 72: unnamed unused input active-high
line 73: unnamed unused input active-high
line 74: unnamed unused input active-high
line 75: unnamed unused input active-high
line 76: unnamed unused input active-high
line 77: unnamed unused input active-high
line 78: unnamed unused input active-high
line 79: unnamed unused input active-high
line 80: unnamed unused input active-high
line 81: unnamed unused input active-high
line 82: unnamed unused input active-high
line 83: unnamed unused input active-high
line 84: unnamed unused input active-high
line 85: unnamed unused input active-high
line 86: unnamed unused input active-high
line 87: unnamed unused input active-high
line 88: unnamed unused input active-high
line 89: unnamed unused input active-high
line 90: unnamed unused input active-high
line 91: unnamed unused input active-high
line 92: unnamed unused input active-high
line 93: unnamed unused input active-high
line 94: unnamed unused input active-high
line 95: unnamed unused output active-high
line 96: unnamed unused input active-high
line 97: unnamed unused input active-high
line 98: unnamed unused input active-high
line 99: unnamed unused input active-high
line 100: unnamed "ACPI:OpRegion" output active-high [used]
line 101: unnamed unused input active-high
gpiochip1 - 28 lines:
line 0: unnamed unused input active-high
line 1: unnamed unused input active-high
line 3: unnamed unused output active-high
line 4: unnamed unused output active-high
line 5: unnamed unused output active-high
line 9: unnamed unused output active-high
line 10: unnamed "backlight" output active-high [used]
line 11: unnamed "panel" output active-high [used]
line 12: unnamed unused output active-high
line 15: unnamed "ACPI:OpRegion" output active-high [used]
line 16: unnamed "home" input active-low [used]
line 17: unnamed unused output active-high
line 18: unnamed unused output active-high
line 19: unnamed unused output active-high
line 20: unnamed unused output active-high
line 21: unnamed unused output active-high
line 22: unnamed unused output active-high
line 23: unnamed unused output active-high
line 24: unnamed "enable" output active-high [used]
line 25: unnamed "device-wake" output active-high [used]
line 26: unnamed unused output active-high
gpiochip2 - 44 lines:
line 1: unnamed "ACPI:OpRegion" output active-high [used]
line 2: unnamed unused output active-high
line 4: unnamed "interrupt" input active-high [used]
line 10: unnamed unused output active-high
line 14: unnamed unused output active-high
line 18: unnamed "ACPI:Event" input active-high [used]
line 20: unnamed "ACPI:OpRegion" output active-high [used]
line 24: unnamed "ACPI:Event" input active-high [used]
line 29: unnamed unused output active-high
line 38: unnamed unused input active-high
line 40: unnamed unused input active-high
gpiochip3 - 3 lines:
line 2: unnamed "ACPI:Event" input active-high [used]
I habe found a suprise in my old Atom …
But for flash STM32 is not a problem RTk.GPIO have CH340G
i have a lot of tools for flash:
But if not possible have a cooked firmware to see in bash with gpiodectect i think buy your board is very powerful or the EBB42 recommended by mykepredko.
But I would like to recover the GTk.GPIO without spending money. Adding a transistor to a high or low logic level is not a problem.
It looks like you have the physical programming tools but not the software which is the more costly piece of the puzzle. You can’t expect anybody to spend any time developing a Klipper firmware image for a unique board (using an MCU that isn’t currently supported by Klipper) if there isn’t anything in it for them.
The RTk.GPIO is an interesting board but I don’t see anybody clamoring for its functionality, especially when there are options, like the EBB42, available that can be used to satisfy the needs that you are looking for very easily.
Sorry there isn’t a Klipper solution for the RTk.GPIO.
I think I will continue to post what I find on the Gtk.GPIO for the moment. Maybe there is someone interested and will come out later.
I hate to sound like a broken record, but the RTk.gpio uses the STM32F030C8T6 and not the STM32F7 that’s referenced in the article you just linked to.
The STM32F030C8T6 is a low-cost Cortex M0 processor with limited peripherals and Flash memory:
The STM32F7 that’s referenced in the linked article contains a much more powerful M7 processor as well as more advanced/comprehensive peripherals and up to megabytes of internal memory and the ability to access external memory devices directly.
I should also point out that the Linux that is referenced in your article is running on the STM32F7 - I’m guessing it’s nommu Linux or some other cut down version of Linux that works without SDRAM/MMU.
Sorry, but there’s no simple route to have the RTk.gpio providing Klipper IO.
The range of “STM32” devices is very broad and encapsulates dozens, if not hundreds, of part numbers, all with different CPUs, memory size and configuration as well as different peripherals. You can’t count on one device in the family to be able to run the same software and interface to a host computer in the same way as another arbitrary device.
Consider RP2040 instead.
