# Stepper 0.9 deg - very noise
**URL:** <https://klipper.discourse.group/t/stepper-0-9-deg-very-noise/6961>\
**Created:** [March 1, 2023, 4:10pm UTC](https://klipper.discourse.group/t/stepper-0-9-deg-very-noise/6961 "2023-03-01T16:10:55Z")\
**Showing post:** 3
**Post date:** [March 26, 2023, 4:10pm UTC](https://klipper.discourse.group/t/stepper-0-9-deg-very-noise/6961/3 "2023-03-26T16:10:10Z")
Interesting topic. In theory I would agree that 0.9° steppers have advances to 1.8° steppers.
[![](https://global.discourse-cdn.com/free1/uploads/klipper/original/2X/7/70689fdb47caccb4db5ddb5e6b946c22e0e514b5.jpeg "LDO Stepper Motors 1.8 vs 0.9 Degree. Battle of the 48mm!") ](https://www.youtube.com/watch?v=nWoUAQyIQb0)
To bad he is not telling which advanced driver settings he used.
I guess settings tuning might help to make the 0.9° steppers quieter.
[![](https://global.discourse-cdn.com/free1/uploads/klipper/original/2X/a/ae98d60dab9ef0b5d436a5728b1a806749fd92c2.jpeg "How to tune stepper drivers "faster ,quieter and cooler"") ](https://www.youtube.com/watch?v=uwkFOvV1BlA)
> [@DrumClock](#):
> [Stepper 0.9 deg - YouTube](https://youtube.com/shorts/KOO4xBDTf84?feature=share)
That sounds nasty 😉
@ReXT3D uses 0.9° steppers
> [@BLTouch unrealistic return values](https://klipper.discourse.group/t/bltouch-unrealistic-return-values/4216/2):
> Because the Z axis movement is quantized by the stepper motor, the values returned by BL Touch cannot be continuous and are also quantized. If you double your Z axis stepper microsteps the quantization you are seeing will reduce in half, etc. EDIT: For example, my modified CR-10S Pro uses 4 mm lead screws with 0.9 degree steppers, which gives me a 0.01 mm resolution per full step. I therefore would get 0.000625 mm resolution per microstep with microsteps set to 16. In practice, I use 64 micr…
maybe he makes a statement here. He even uses 64 microsteps!
Good luck, hcet14
_[View the full topic](https://klipper.discourse.group/t/stepper-0-9-deg-very-noise/6961)._
