# Tmp007. IR sensor used to check top surface of bed
**URL:** <https://klipper.discourse.group/t/tmp007-ir-sensor-used-to-check-top-surface-of-bed/4067>\
**Created:** [September 6, 2022, 9:30pm UTC](https://klipper.discourse.group/t/tmp007-ir-sensor-used-to-check-top-surface-of-bed/4067 "2022-09-06T21:30:56Z")\
**Showing post:** 5
**Author:** ![jules](https://avatars.discourse-cdn.com/v4/letter/j/41988e/32.png) [@jules](https://klipper.discourse.group/u/jules)\
**Post date:** [September 7, 2022, 4:04pm UTC](https://klipper.discourse.group/t/tmp007-ir-sensor-used-to-check-top-surface-of-bed/4067/5 "2022-09-07T16:04:26Z")
maybe some info for reading.
there are smart 🤓 people who made macro’s that used a bed sensor and a top sensor to calculate heat soak time
github: [klipper-voron2.4-config/heatsoak.cfg at mainline · garethky/klipper-voron2.4-config · GitHub](https://github.com/garethky/klipper-voron2.4-config/blob/mainline/klipper-config/heatsoak.cfg)
topic post for info : [Interruptible heat soak - #3 by elpeter](https://klipper.discourse.group/t/interruptible-heat-soak/1552/3)
the github version uses a extra sensor for calculating heatsoak
edit: after inspecting the topic i saw you also commented in there, little bit of old news then 😅
_[View the full topic](https://klipper.discourse.group/t/tmp007-ir-sensor-used-to-check-top-surface-of-bed/4067)._
