Unstable hotend temperature on Trident
Check the thermistor with a soldering iron if you have one with digital temperature controls.
I did not seemed it neccessary. As i said before i am doing update for EBB and Dragon so this will remove any potentional issues with cabling.
During removal process I will remove thermistor along with cable and will try to determine what was issue.
I also marked one answer as correct solution. Thanks
