Using Klipper Macros for Comments/Versioning Information
As I was working through getting the TMC2240, I wanted to have some way of being able to track the changes to printer.cfg and have them visible in the klippy.log so I could track what changes resulted in different connection/execution issues just be scrolling up/down rather than consulting another document (paper or digital).
This worked out very well for me and I wondered about using this approach for not only notes regarding configuration change text but also using to record the version information of the printer.cfg like:
[gcode_macro version]
variable_line01: "****************************************************************"
variable_line02: "** 2025.11.22 - Initial Version, Test TMC2240 Operation       **"
variable_line03: "**            - Copied in Original manual_stepper printer.cfg **"
variable_line99: "****************************************************************"
It’s nice to have as a reference to go back on when debugging.
Will doing this have any negative impact to the operation or speed of Klipper?
I’m asking because I would expect the typical macro data size required in a printer instance to be normally in hundreds of bytes, if not tens, and doing this could very quickly increase into thousands of bytes.
I’d guess it wouldn’t be an issue. That info is only stored in the host computer so it doesn’t impact the micro-controllers. The GUI frontends will often read the config, which would convey that information, so it is a little more information sent over the “webhooks api”. As long as you kept it to under a few 100KB I doubt it would be an issue.
That’s what I thought.
I just looked at my longest version comments in a printer.cfg and it’s around 8k.
I’m loquacious in my version commenting but you’re talking a couple of orders of magnitude more than I would expect version information/specifics to take up.
Thanx for the reply.
As afar as I know, some values, as the date, have been automatically captured from somewhere, or you mean that you need to write the date each time you make changes?
I typically track changes by date but, as I said in the OP, I started doing this when I was experimenting with different settings and I wanted a more easily read and tracked record specific to the printer.cfg version referenced with the information following it in the printer’s klippy.log.
