Nice!
Could you please format your code with the code braces:
All leading spaces are gone without that.
Nice!
[gcode_macro SENSORLESS_HOME_X]
{% set HOME_CUR = 0.700 %}
{% set driver_config = printer.configfile.settings['tmc2209 stepper_x'] %}
{% set RUN_CUR = driver_config.run_current %}
# Set current for sensorless homing
SET_TMC_CURRENT STEPPER=stepper_x CURRENT={HOME_CUR}
# Pause to ensure driver stall flag is clear
G4 P2000
# Home
G28 X0
# Move away
G90
G1 X157 F1200
# Set current during print
SET_TMC_CURRENT STEPPER=stepper_x CURRENT={RUN_CUR}
[gcode_macro SENSORLESS_HOME_Y]
{% set driver_config = printer.configfile.settings['tmc2209 stepper_y'] %}
SET_TMC_CURRENT STEPPER=stepper_y CURRENT={HOME_CUR}
G4 P2000
# Home
G28 Y0
# Move away
G90
G1 Y174 F1200
SET_TMC_CURRENT STEPPER=stepper_y CURRENT={RUN_CUR}
[homing_override]
axes: z
set_position_z: 0
G90
G0 Z6 F600
{% set home_all = 'X' not in params and 'Y' not in params and 'Z' not in params %}
{% if home_all or 'X' in params %}
SENSORLESS_HOME_X
{% if home_all or 'Y' in params %}
SENSORLESS_HOME_Y
{% if home_all or 'Z' in params %}
G28 Z
G0 Z10 F1800
Can I ask why you set your final toolhead raise:
G0 Z10 F1800
Is so fast? I’m not sure what kind of Z axis motion drive you have but if you got that kind of speed, aren’t you going to get a hell of a jerk?
hello you can edit to your liking, for now I set up this way because I’m still finishing to fix everything. The configuration is fine but I have to finish optimizing.
I get that you’re going to be looking at things, but this is an honest order of magnitude faster than what most people use for Z movement - that’s why I reacted and asked.
Have you actually run with the Z movement at this speed?
Hello,
I know this topic is solved… I can only say that jinja or flask or whatever tool you use as a microframework in html type coding within the .cfg or other python2/3 scripts should not have many if statements. It slows the process…
I think this is the reference to who made jinja?
Anyway…I will get the actual template describing why/how jinja html if statements slows down things in general.
Seth
P.S. Template Designer Documentation — Jinja Documentation (3.1.x) states that expressions are available in any form but that using it in html makes things different: Template Designer Documentation — Jinja Documentation (3.1.x) .
I am not saying jinja is indeed a cure or a foe but only that it gets as complicated as other formulary programs… If I am off base, okay. I just figured some people may want to see how html and python like expressions create issues in the case of making html called whatever but using it as html.
I know this is not Jinja course work studies. So, no big woof here but!
How much does an “if” statement in a jinja2 .cfg slow things down? I would think that we’re talking single digit milliseconds at most to evaluate an {% if <cond> %} statement and branch to the appropriate locations for execution. I doubt it would be noticeable across a print.
Now, I do agree that the use of conditional execution statements in a macro should be minimized simply because there is no decent way of debugging complex operations and, unless you have lots of echo statements for tracking actual execution , you may not know how they will actually execute.
For now yes but only for this small movement in the home phase. In printing, the axis to these parameters:
[printer]
kinematics: corexy
max_velocity: 300
max_accel: 3000
max_accel_to_decel: 3000
max_z_velocity: 14
max_z_accel: 40
I believe (and, if I’m wrong I’m sure I will hear about it) that the two values are separate for their respective operations.
You have a reasonable value for Z axis movement while printing and and a real potential jerk after doing your homing which I would think could affect the final position of the toolhead after the Z axis movement. I would be concerned that the steppers driving the leadscrews can turn fast enough for that speed.
I would suggest a value for “F” of 600 or so after homing.
okay
Then I’ll update you I’m putting the tmc5160pro. What I posted now refers to Stepper TMC 2209
