Abom's Kipper Menu
This is an updated version of the menu that used to be on the Klipper.info, which will probably be going away. Change line 20 if you want to use Octoprint.
[menu __main]
type: list
[menu __main __tune]
type: list
enable: {printer.idle_timeout.state == “Printing”}
index: 1
[menu __main __calibrate]
type: list
enable: {not printer.idle_timeout.state == “Printing”}
index: 2
[menu __main __octoprint]
type: list
enable: false
[menu __main __sdcard]
type: vsdlist
enable: false
[menu __main __calibrate __calibration_home_all_axes]
type: command
gcode: G28
[menu __main __calibrate __calibration_probe_calibrate]
type: list
name: Probe Calibrate
[menu __main __calibrate __calibration_probe_calibrate __calibrate]
type: command
{% set ns = namespace(NEED2HOME = false) %}
{% for AXIS in [“x”, “y”, “z”] %}
{% if AXIS not in printer.toolhead.homed_axes %}
{% set ns.NEED2HOME = true %}
{% endfor %}
{% if ns.NEED2HOME == true %}
G28
PROBE_CALIBRATE
[menu __main __calibrate __calibration_probe_calibrate __adjust_Z+1]
type: command
name: Z+1: {’%05.1f’ % printer.gcode_move.position.z}
gcode: TESTZ Z=+1
[menu __main __calibrate __calibration_probe_calibrate __adjust_Z-1]
type: command
name: Z-1: {’%05.1f’ % printer.gcode_move.position.z}
gcode: TESTZ Z=-1
[menu __main __calibrate __calibration_probe_calibrate __adjust_Z+.1]
type: command
name: Z+.1: {’%05.1f’ % printer.gcode_move.position.z}
gcode: TESTZ Z=+.1
[menu __main __calibrate __calibration_probe_calibrate __adjust_Z-.1]
type: command
name: Z-.1: {’%05.1f’ % printer.gcode_move.position.z}
gcode: TESTZ Z=-.1
[menu __main __calibrate __calibration_probe_calibrate __adjust_Zpp]
type: command
name: Z+: {’%05.1f’ % printer.gcode_move.position.z}
gcode: TESTZ Z=+
[menu __main __calibrate __calibration_probe_calibrate __adjust_Zmm]
type: command
name: Z-: {’%05.1f’ % printer.gcode_move.position.z}
gcode: TESTZ Z=-
[menu __main __calibrate __calibration_probe_calibrate __calibration_accept]
type: command
ACCEPT
SAVE_CONFIG
{(menu.back.True)}
[menu __main __calibrate __calibration_probe_calibrate __calibration_abort]
type: command
ABORT
{(menu.back.True)}
[menu __main __calibrate __manual_bed_screw_calibrate]
type: list
name: Man. Bed Screw Calib.
[menu __main __calibrate __manual_bed_screw_calibrate __bed_screws_adjust]
type: command
name: Adjust Bed Screws
BED_SCREWS_ADJUST
[menu __main __calibrate __manual_bed_screw_calibrate __accept]
type: command
ACCEPT
[menu __main __calibrate __manual_bed_screw_calibrate __adjusted]
type: command
ADJUSTED
{(menu.back.True)}
Here’s the same config, but in a code block so that it doesn’t get messed up:
[menu __main]
type: list
type: list
enable: {printer.idle_timeout.state == "Printing"}
index: 1
type: list
enable: {not printer.idle_timeout.state == "Printing"}
index: 2
type: list
enable: false
type: vsdlist
enable: false
type: command
gcode: G28
type: list
type: command
  {% for AXIS in ["x", "y", "z"] %}
  {% endfor %}
    G28
  PROBE_CALIBRATE
type: command
name: Z+1: {'%05.1f' % printer.gcode_move.position.z}
gcode: TESTZ Z=+1
type: command
name: Z-1: {'%05.1f' % printer.gcode_move.position.z}
gcode: TESTZ Z=-1
type: command
name: Z+.1: {'%05.1f' % printer.gcode_move.position.z}
gcode: TESTZ Z=+.1
type: command
name: Z-.1: {'%05.1f' % printer.gcode_move.position.z}
gcode: TESTZ Z=-.1
type: command
name: Z+: {'%05.1f' % printer.gcode_move.position.z}
gcode: TESTZ Z=+
type: command
name: Z-: {'%05.1f' % printer.gcode_move.position.z}
gcode: TESTZ Z=-
type: command
  ACCEPT
  SAVE_CONFIG
  {(menu.back.True)}
type: command
  ABORT
  {(menu.back.True)}
type: list
type: command
gcode: BED_SCREWS_ADJUST
type: command
gcode: ACCEPT
type: command
  ADJUSTED
  {(menu.back.True)}
