Animated screensaver support
ezgif.com-gif-maker
Any interest?
It’s simple - added a single line of python code to add a time variable accessible to the display templates (so we can use modulo for frame number etc., as per the spinning fan examples). I didn’t want to spend any time on the design, hence the simple example, but I don’t see any reason you couldn’t display anything from a (black and white) gif of the right size.
FWIW I don’t think klipper should generally offer this as a feature - but if adding a ticker variable allows people to make their own screensaver macros, no harm done?
Interesting. FWIW, there is a time variable currently available (via printer.toolhead.estimated_print_time). Take a look at how klippy/extras/display/display.cfg implements animations via the existing time variable.
Thanks Kevin - that’s how I do my other ones, but I thought I checked and it wasn’t useful while not printing (as the name implies). Turns out it I was wrong, woops. That means no dev is needed, so I’ll see if I can move this to the macros topic - though unless there’s a heap of interest (and someone provides a cool animated klipper logo) maybe best to leave it.
Side note - I realised I could go beyond a screensaver and a add a basic lock screen (which you unlock with menu inputs like a digital combination lock) by just abusing some templates and gcode variables etc. Again, fun, but maybe not worth it.
Really interesting, could you describe the step by step process to enable the animated screensaver?
Thanks in advance
