Hello, I have assembled a printer with dual extruders where the hotends are mounted as a single group on the X-axis. Both extruders have a lifting carriage and a sensor to detect upward movement. Currently, I use this setup for bed leveling with only the right nozzle.
However, I would like to implement a system to detect the height difference between the two nozzles before starting a dual filament print. I am not sure how to proceed, and I’m wondering if it’s possible to achieve this through a macro. Do you have any advice or suggestions on how I could address this situation?
It seems possible.
Build a macro which will activate first extruder then do a probe,
Then query “last_z_result” from Probe and store to variable_1.
Then switch to second extruder and do probe again.
Then query “last_z_result” from Probe and store to variable_2.
Calculate difference.
Done.
