Printer Model: Ratrig Vcore3
MCU / Printerboard: Octopus Pro + EBB42 (by can)
klippy.log (2.1 MB)
recently, yesterday, I have installed an EBB42 by Can, until now I had it by USB, but since it had disconnections, I have changed it to CAN.
I thought that the disconnection problems were over, but in the first impression after the installation shortly after starting, in the first layer I received this message and the impression has stopped.
MCU ‘EBBCan’ shutdown: Timer too close
This often indicates the host computer is overloaded. Check
for other processes consuming excessive CPU time, high swap
usage, disk errors, overheating, unstable voltage, or
similar system problems on the host computer.
Printer is shutdown
Why can this be?
It’s an Rpi4, so I don’t think this is overloaded
The temperature of Rpi is 49º
Ideas?
