CANBUS Missed scheduling of next digital out event
I’m dumb, I just needed to install crowsnest and sonar…
Yes, it’s a CM3+ with 8GB eMMC. I’m not trying to cut things down, I just have a lot of them.
…I could try disabling the emmc and slap and SD card in there… or use a Pi4…
I just find it odd that the MainsailOS has everything installed + KIAUH and I still have over 1GB of space and the manual install with KIAUH the free space is about 3-400MB. It’s provably a Bullseye Bookworm thing…
I observed the same thing regarding the image size and there are a number of people here that swear by the Mainsail OS Image.
It should be noted that my experience with Mainsail OS was around two years ago and I’ve ditched using U2C boards and only work with main controller boards that have a CAN port built in and I’m setting them up as as USB to CAN bridges.
Let us know what you decide to do/try.
FYI, I did some further research on this. It looks to me that we should recommend Linux v6.6.0 or later, candlelight_fw v2.0 or later, and Klipper v0.12.0 or later. I’ve proposed an update to the Klipper documentation to make this more clear: Improve suggestions on bytes_invalid in CANBUS_Troubleshooting.md by KevinOConnor · Pull Request #6810 · Klipper3d/klipper · GitHub
EDIT: It’s Linux v6.6.0 that is needed for the fix.
Well… i killed my printer mainboard with a funky flash update, will see how to recover it later…
I tried to build a Raspi OS Minimal image and it turned out to be a Lite image, but it’s a bit smaller than the official Lite image at least… will try again…
Just got some nice can cable from work at least:
cool
Product page Lapp
It does look interesting. The only comment I have is that the wires inside the cable are a bit light for the current needed for a toolhead - I would want to see at least 2A (for the extruder heater) and 0.5mm^2 is good for 1.5A.
Yearrrgggg, @hcet14, I did not need to see the price hahahaha!!!
@mykepredko, sadly its the 1x2x0.25mm^2 so I will still keep the installed power cables.
I’m getting out of here in a couple mins and I’m going straight home to see if I can save the Mainboard or not hahahaha (:sob:).
It’s for 100m of the cable - Digi-Key is waiting to get some in and you should be able to buy it from them for shorter lengths.
I don’t agree.
This is the formula I took to calculate the ampacity Electrical resistivity and conductivity - Wikipedia
I=(A x U)/(2 x rho x l) DC Wire Size Calculator
I calculated conservative.
A=0,5mm²=0,0000005m²
U=0,48V@24V (Voltage drop(2%) of 24V)
roh=2.05×10−8Ohm x m@20°C
l=Cable lengths (one way)=2m
I get 2.93A.
Your calculations are for single conductor wires - multi-stranded wires cannot carry as much current as single conductor wires.
I’m going by standards charts like:
Wire Gauge and Current Limits Including Skin Depth and Tensile Strength
Which says that 20AWG (0.5mm^2) can transmit up to 1.5A of power which is why I said it’s “a bit light” - for a toolhead, I want to see a rating of at least 2A would be most comfortable with 2.5A.
Regardless, when it becomes available at Digi-Key and I can buy it in something less than 100m lengths, I’ll make up a cable or two and try it out.
Went back from the Pi4 to the CM3+.
I ended up building Armbian Minimal and I now have nearly 3GB of free space after installing everything and no can issues.
:green_heart:
Thanks for the help!!
I don’t think that’s the right way to get the value of ampacity of a wire.
When I read that link, I find
“Voltage Drop Calculator by Gerald Newton http://www.electrician2.com
That goes to nothing and there is no equation given how the voltage drop was calculated.
The equation I mentioned above includes temperature.
You mentioned
I totally agree, but we are talking about an 3D printer environment.
Without an enclosure we may have (just guessing) 10°C above ambient temperature. With an enclosure we may have 60°C to 80°C or more. Temperature is very important before giving an estimate about the ampacity of a cable.
I found another interesting cable (Lapp) from Lapp (1x2xAWG24 + 1x 2xAWG22). The wire gauges and diameter are interesting.
