Printer Model: ratrig v3
MCU / Printerboard: Octopus pro
I’m trying to change the direction of the extruder… other times I’ve done it, but now I can’t. Despite changing it, it keeps turning backwards.
I have looked at the “klippy.log” and although I put ! in front of the direction pin, in the log it is still shown as it was before…
I attach extracts, the extruder motor, I have it connected to a SHT42… with this configuration.
step_pin: SHT42:PB4
dir_pin: !SHT42:PB3
enable_pin: !SHT42:PA15
rotation_distance: 33.50
full_steps_per_rotation: 200
nozzle_diameter: 0.400
filament_diameter: 1.750
max_extrude_only_velocity: 60
heater_pin: SHT42:PA8
sensor_pin: SHT42:PB0
pullup_resistor: 2200
control: pid
pid_Kp: 30.466
pid_Ki: 1.707
pid_Kd: 135.953
min_temp: -50
max_temp: 350
You can see like i have put ! in the dir_pin: “dir_pin: !SHT42:PB3”
but if you look attached log… the ! there isnt… i have saved and restart multiple times…
klippy.log (4.7 MB)
