Communication timeout during homing x or Y
Hi Everyone
hope you can get me pointed in the right direction with this error I’m having.
I’m building a COREXY machine with Rpi + waveshare CANhat, BTT Octopus Pro and a Mellow SHT42 tool head PCB. Both MCUs are connected to the CANhat using CAN. Im getting a random and intermittent error when homing either X or Z.
Communication timeout during homing x is the message I’m seeing in the console. I’m stuck basically is there anything in the logs that would suggest where to look?
I’ve attached a log showing a successful full home and then an unsuccessful attempt at homing X.
Thanks
klippy.log (69.5 KB)
moonraker.log (52.9 KB)
Can anyone offer any help?
A “Communication timeout during homing” error indicates that the micro-controllers were unable to provide status updates every 25ms and the homing was therefore aborted. Looking at your log, there are several cases that show a high round-trip-time (look for srtt in the logs). It’s not clear why there is a high round-trip-time, but make sure your CAN bus speed is 500000 or higher.
Thanks Kevin,
I think ive solved this but I’m not sure what it actually dies…
The waveshare instructions say add dtoverlay=mcp2515-can0,oscillator=12000000,interrupt=25,spimaxfrequency=2000000 to the config.
I found another klipper user that suggested removing spimaxfrequency=2000000. I’ve not had an issue since.
Thanks
Michael
Hi please could you help, which config, where and how did you manage to add dtoverlay=mcp2515-can0,oscillator=12000000,interrupt=25,spimaxfrequency=2000000 to the config.
I would like to try this .
Hey Peter,
This is a good instructional video to follow
Klipper Mainsail CAN Setup Guide - Huvud - YouTube
