Printer Model: Sovol SV07
MCU / Printerboard: N/A (builtin)
[klippy.log|attachment](upload://hTgA88DdJApneeumN30w9ReO1jX.log) (937.1 KB)
Fill out above information and in all cases attach your klippy.log
file (use zip to compress it, if too big). Pasting your printer.cfg
is not needed
I tried to create a gcode macro for loading filament - at the end, if the printer is not paused during an active print, I want it to shut off the hotend. Using the Status Reference page (Status reference - Klipper documentation), I determined the way to do this is using the pause_resume object’s is_paused reference. So, I added a conditional statement checking this:
{% if pause_resume.is_paused == False %}
M104 S0
However, when I tried to use this macro, I received the error “!! Error evaluating ‘gcode_macro LOAD_FILAMENT:gcode’: jinja2.exceptions.UndefinedError: ‘pause_resume’ is undefined”
I’ve found examples elsewhere that seem to indicate I need to prepend the status reference identifier with printer (i.e. printer.pause_resume.is_paused), but this is not evident anywhere in the actual documentation I can find. Have I missed something, or should this be submitted as a bug report to the documentation to explicitly indicate that all objects on that list need to be prepended with “printer.”?
Thanks in advance for your help
