All corrected, still does the same stuff.
klippy Mon Test 7.log (22.7 KB)
Since I did the initial setup to the M8P on Friday, there were some updates across Klipper, mainsail,… I did all of those and tested, observed no change. Uninstalled and reinstalled klipper on the CB1, no change.
I placed two brand new TMC2209 drivers in the Motor 7/8 slots. Migrated all of the pins. No difference.
I’m thinking there is some bug kinematic issue in the base firmware…?
You are messing yourself back and forth through the settings and now it is a bug? Highly unlikely.
Temps are good
M112 is good
Heaters all work
Enable pins do work
ENDSTOPS all respond correctly
StepperBuzz Y moves +/-
StepperBuzz X moves +/+, no negative.
Swapped X and Y motors, issues followed the driver.
Moved the X to an unused driver. updated config, Now stepperbuzz X moves +/-.
Tried to Home, found homing in the incorrect directions. Swapped the motor connections and found the correct X-/Y- directions. It would attempt to home, found some issues with homing retraction distances, fixed those. Now it will home both X and Y in the correct directions.
I still have a few more things to figure out but I think that is it. @Sineos, Thank You. I was trying to work around some of necessary steps to find the issues with not moving in multiple directions. ThisGuy really appreciated your help.
