Creality CR-ERA V1.1.0.3 board can't flash Kliper firmware - Error 255
Printer Model: Cerality CR6 Max
MCU / Printerboard: STM32F103CR-ERA V1.1.0.3 board
klippy.log (153.0 KB)
klippy (last attempt).log (217.6 KB)
I’m trying to flash my firmware to my printer. I’ve tried all several combinations of FW compile setup with no success. All I’m getting from mainsail is: mcu 'mcu': Unable to connect. Electronics work because when I’ve tried to connect to it with octoprint from a PC, there’s no problem.
Here are all config options I’ve tried so far:
  • Processor model: STM32F103
  • Only 10KiB of RAM: both
  • Disable SWD at startup: false
  • Bootloader offset: 28KiB
  • Clock Reference: 8 MHz crystal
  • Communication interface: Serial on USART1 PA10/PA9
  • Baud rate of serial port: 115200 - same as octoprint
  • GPIO pins to set at micro-controller startup: empty
I was also getting Error 255 when I was flashing it directly from SBC to printer. Using SD didnt’t help.
Hello @lamp-town-guy !
I assume you mean these her?
https://www.klipper3d.org/Bootloaders.html#stm32f103-micro-controllers-blue-pill-devices
Yes it’s correct. But it don’t understand how any of that would help me. Because I was using both SD card and USB connection without any success.
Try:
  • Microcontroller - “STM32”
  • Processor model “STM32F103”
  • Bootloader - “28KiB”
  • Communication interface “Serial (on USART1 PA10/PA9)”
Leave the rest default and make sure your SD card is FAT32 with 4096 bits sector size
I’m not 100% sure if this helped or me unplugging USB port from the SBC. But I was surprised that it just worked all of a sudden.
how to unplugging USB port from the SBC,please help me
Don’t hijack an old thread with an completely different question!
Open a new thread under General Discussion topic if really needed.
Additionally what are you asking for? Just pull the USB connector/cable out of the port.
