DS18B20 Temperature Sensor Configuration
Dear all,
i do have a problem connecting a DS18B20 Temperature Sensor to my Raspberry pi 2b.
I connected VCC to 5V, GND to GND and Sig to GPIO 4.
Now i want to find out the serial number, however with no success:
First there is no /sys/bus/w1/devices/ and after giving some command i found online i see no serial number …
pi@fluiddpi:~ $ cd /sys/bus/w1/devices/
-bash: cd: /sys/bus/w1/devices/: No such file or directory
pi@fluiddpi:~ $ sudo modprobe w1-gpio
pi@fluiddpi:~ $ sudo modprobe w1-therm
pi@fluiddpi:/sys/bus/w1/devices $ ls
pi@fluiddpi:/sys/bus/w1/devices $ ^C
What am i doing wrong? :frowning:
Can someone help?
PS i used KIAUH to install Fluidd and klipper
It is never good to use the same colour for VCC and GND.
Did you check those cables twice already?
  1. Call sudo raspi-config
  2. Activate the 1-wire interface
  3. Reboot
  4. Call lsmod | grep -i w1_ to verify that the needed Kernel modules are actually loaded
Hello, thank you for your answers.
Just before you wrote the answer i got the sensor to work in ssh.
I followed this thread w1-gpio & w1-therm in etc/modules not recognized. - Raspberry Pi Forums
But i am getting errors in Fluidd.
I added this to my printer.cfg
[temperature_sensor Chamber]
sensor_type = DS18B20
serial_no = 28-030897945420
ds18_report_time = 1.0
sensor_mcu = host_mcu
I am getting this error after restart:
Unknown config object ‘mcu host_mcu’
Already tried sensor_mcu = host but didnt work…
Post your klippy.log
klippy.log (381.6 KB)
i changed it to
sensor_mcu = mcu
But now i am getting …
MCU Protocol error
This is frequently caused by running an older version of the
firmware on the MCU(s). Fix by recompiling and flashing the
firmware.
Your Klipper version is: v0.11.0-148-g52f4e20c
MCU(s) which should be updated:
Up-to-date MCU(s):
mcu: Current version v0.11.0-148-g52f4e20c
Once the underlying issue is corrected, use the "RESTART"
mcu 'mcu': Unknown command: config_ds18b20
Not sure if i have to flash a newer firmware or i did something wrong in the config :X
Follow RPi microcontroller - Klipper documentation
Do you mean i have to setup a second mcu on my RPI only to display the temperature values?
Not sure if i want to touch a smooth running system only for that to be honest.
Are there other advantages or am i getting it wrong?
Because by setting
[temperature_sensor raspberry_pi]
sensor_type: temperature_host
i can see the RPi Temperature
See Klipper Architecture / Ecosystem for how Klipper works.
If you want to connect any additional hardware to the RPi’s GPIOs, like 1-wire, IMUs etc, then you have no other choice.
Be sure to mind the limitations listed here Configuration reference - Klipper documentation
Thank you for the hint. I was not aware of this.
I set the RPI as a second mcu and now the temperature sensor is working well.
Was less effort than expected in the end :slight_smile:
Hi! It is possible to use DS1821S? i think it´s not, because in config reference only exists DS18B20, could be added to klipper as they are very similar?
