Error: tmc virtual endstop requires diag pin config
Printer Model: Custom
MCU / Printerboard:Duet 3
Host / SBC Raspberry Pi 3b
===== Config file =====
[virtual_sdcard]
path = ~/printer_data/gcodes
on_error_gcode = CANCEL_PRINT
[pause_resume]
[display_status]
[respond]
[gcode_macro CANCEL_PRINT]
description = Cancel the actual running print
rename_existing = CANCEL_PRINT_BASE
gcode =
{% set client = printer['gcode_macro _CLIENT_VARIABLE']|default({}) %}
{% set allow_park = client.park_at_cancel|default(false)|lower == 'true' %}
{% set retract = client.cancel_retract|default(5.0)|abs %}
{% set park_x = "" if (client.park_at_cancel_x|default(none) is none)
else "X=" ~ client.park_at_cancel_x %}
{% set park_y = "" if (client.park_at_cancel_y|default(none) is none)
else "Y=" ~ client.park_at_cancel_y %}
{% set custom_park = park_x|length > 0 or park_y|length > 0 %}
{% if printer['gcode_macro RESUME'].restore_idle_timeout > 0 %}
SET_IDLE_TIMEOUT TIMEOUT={printer['gcode_macro RESUME'].restore_idle_timeout}
{% if (custom_park or not printer.pause_resume.is_paused) and allow_park %} _TOOLHEAD_PARK_PAUSE_CANCEL {park_x} {park_y} {% endif %}
_CLIENT_RETRACT LENGTH={retract}
TURN_OFF_HEATERS
M106 S0
{client.user_cancel_macro|default("")}
SET_GCODE_VARIABLE MACRO=RESUME VARIABLE=idle_state VALUE=False
SET_PAUSE_NEXT_LAYER ENABLE=0
SET_PAUSE_AT_LAYER ENABLE=0 LAYER=0
CANCEL_PRINT_BASE
[gcode_macro PAUSE]
description = Pause the actual running print
rename_existing = PAUSE_BASE
gcode =
{% set idle_timeout = client.idle_timeout|default(0) %}
{% set temp = printer[printer.toolhead.extruder].target if printer.toolhead.extruder != '' else 0 %}
{% set restore = False if printer.toolhead.extruder == ''
else True  if params.RESTORE|default(1)|int == 1 else False %}
SET_GCODE_VARIABLE MACRO=RESUME VARIABLE=last_extruder_temp VALUE="{{'restore': restore, 'temp': temp}}"
{% if idle_timeout > 0 %}
SET_GCODE_VARIABLE MACRO=RESUME VARIABLE=restore_idle_timeout VALUE={printer.configfile.settings.idle_timeout.timeout}
SET_IDLE_TIMEOUT TIMEOUT={idle_timeout}
PAUSE_BASE
{client.user_pause_macro|default("")}
_TOOLHEAD_PARK_PAUSE_CANCEL {rawparams}
[gcode_macro RESUME]
description = Resume the actual running print
rename_existing = RESUME_BASE
variable_last_extruder_temp = {‘restore’: False, ‘temp’: 0}
variable_restore_idle_timeout = 0
variable_idle_state = False
gcode =
{% set velocity = printer.configfile.settings.pause_resume.recover_velocity %}
{% set sp_move = client.speed_move|default(velocity) %}
{% set runout_resume = True if client.runout_sensor|default("") == ""
else True if not printer[client.runout_sensor].enabled
else printer[client.runout_sensor].filament_detected %}
{% set can_extrude = True if printer.toolhead.extruder == ''
else printer[printer.toolhead.extruder].can_extrude %}
{% set do_resume = False %}
{% set prompt_txt = [] %}
{% if printer.idle_timeout.state|upper == "IDLE" or idle_state %}
{% if last_extruder_temp.restore %}
RESPOND TYPE=echo MSG='{"Restoring \"%s\" temperature to %3.1f\u00B0C, this may take some time" % (printer.toolhead.extruder, last_extruder_temp.temp) }'
M109 S{last_extruder_temp.temp}
{% set do_resume = True %}
{% elif can_extrude %}
{% else %}
RESPOND TYPE=error MSG='{"Resume aborted !!! \"%s\" not hot enough, please heat up again and press RESUME" % printer.toolhead.extruder}'
{% set _d = prompt_txt.append("\"%s\" not hot enough, please heat up again and press RESUME" % printer.toolhead.extruder) %}
{% else %}
{% if runout_resume %}
{% if do_resume %}
{% if restore_idle_timeout > 0 %} SET_IDLE_TIMEOUT TIMEOUT={restore_idle_timeout} {% endif %}
{client.user_resume_macro|default("")}
_CLIENT_EXTRUDE
RESUME_BASE VELOCITY={params.VELOCITY|default(sp_move)}
{% else %}
RESPOND TYPE=error MSG='{"Resume aborted !!! \"%s\" detects no filament, please load filament and press RESUME" % (client.runout_sensor.split(" "))[1]}'
{% set _d = prompt_txt.append("\"%s\" detects no filament, please load filament and press RESUME" % (client.runout_sensor.split(" "))[1]) %}
{% if not (runout_resume and do_resume) %}
RESPOND TYPE=command MSG="action:prompt_begin RESUME aborted !!!"
{% for element in prompt_txt %}
RESPOND TYPE=command MSG='{"action:prompt_text %s" % element}'
{% endfor %}
RESPOND TYPE=command MSG="action:prompt_footer_button Ok|RESPOND TYPE=command MSG=action:prompt_end|info"
RESPOND TYPE=command MSG="action:prompt_show"
[gcode_macro SET_PAUSE_NEXT_LAYER]
description = Enable a pause if the next layer is reached
gcode =
{% set pause_next_layer = printer[‘gcode_macro SET_PRINT_STATS_INFO’].pause_next_layer %}
{% set ENABLE = params.ENABLE|default(1)|int != 0 %}
{% set MACRO = params.MACRO|default(pause_next_layer.call, True) %}
SET_GCODE_VARIABLE MACRO=SET_PRINT_STATS_INFO VARIABLE=pause_next_layer VALUE=“{{ ‘enable’: ENABLE, ‘call’: MACRO }}”
[gcode_macro SET_PAUSE_AT_LAYER]
description = Enable/disable a pause if a given layer number is reached
gcode =
{% set pause_at_layer = printer[‘gcode_macro SET_PRINT_STATS_INFO’].pause_at_layer %}
{% set ENABLE = params.ENABLE|int != 0 if params.ENABLE is defined
else params.LAYER is defined %}
{% set LAYER = params.LAYER|default(pause_at_layer.layer)|int %}
{% set MACRO = params.MACRO|default(pause_at_layer.call, True) %}
SET_GCODE_VARIABLE MACRO=SET_PRINT_STATS_INFO VARIABLE=pause_at_layer VALUE=“{{ ‘enable’: ENABLE, ‘layer’: LAYER, ‘call’: MACRO }}”
[gcode_macro SET_PRINT_STATS_INFO]
rename_existing = SET_PRINT_STATS_INFO_BASE
description = Overwrite, to get pause_next_layer and pause_at_layer feature
variable_pause_next_layer = { ‘enable’: False, ‘call’: “PAUSE” }
variable_pause_at_layer = { ‘enable’: False, ‘layer’: 0, ‘call’: “PAUSE” }
gcode =
{% if pause_next_layer.enable %}
RESPOND TYPE=echo MSG=‘{“%s, forced by pause_next_layer” % pause_next_layer.call}’
{pause_next_layer.call}
{% elif pause_at_layer.enable and params.CURRENT_LAYER is defined and params.CURRENT_LAYER|int == pause_at_layer.layer %}
RESPOND TYPE=echo MSG=‘{“%s, forced by pause_at_layer [%d]” % (pause_at_layer.call, pause_at_layer.layer)}’
{pause_at_layer.call}
SET_PRINT_STATS_INFO_BASE {rawparams}
[gcode_macro _TOOLHEAD_PARK_PAUSE_CANCEL]
description = Helper: park toolhead used in PAUSE and CANCEL_PRINT
gcode =
{% set use_custom     = client.use_custom_pos|default(false)|lower == 'true' %}
{% set custom_park_x  = client.custom_park_x|default(0.0) %}
{% set custom_park_y  = client.custom_park_y|default(0.0) %}
{% set park_dz        = client.custom_park_dz|default(2.0)|abs %}
{% set sp_hop         = client.speed_hop|default(15) * 60 %}
{% set sp_move        = client.speed_move|default(velocity) * 60 %}
{% set origin    = printer.gcode_move.homing_origin %}
{% set act       = printer.gcode_move.gcode_position %}
{% set max       = printer.toolhead.axis_maximum %}
{% set cone      = printer.toolhead.cone_start_z|default(max.z) %}
{% set round_bed = True if printer.configfile.settings.printer.kinematics is in ['delta','polar','rotary_delta','winch']
else False %}
{% set z_min = params.Z_MIN|default(0)|float %}
{% set z_park = [[(act.z + park_dz), z_min]|max, (max.z - origin.z)]|min %}
{% set x_park = params.X       if params.X is defined
else custom_park_x  if use_custom
else 0.0            if round_bed
else (max.x - 5.0) %}
{% set y_park = params.Y       if params.Y is defined
else custom_park_y  if use_custom
else (max.y - 5.0)  if round_bed and z_park < cone
else (max.y - 5.0) %}
_CLIENT_RETRACT
{% if "xyz" in printer.toolhead.homed_axes %}
G90
G1 Z{z_park} F{sp_hop}
G1 X{x_park} Y{y_park} F{sp_move}
{% if not printer.gcode_move.absolute_coordinates %} G91 {% endif %}
{% else %}
RESPOND TYPE=echo MSG='Printer not homed'
[gcode_macro _CLIENT_EXTRUDE]
description = Extrudes, if the extruder is hot enough
gcode =
{% set use_fw_retract = (client.use_fw_retract|default(false)|lower == 'true') and (printer.firmware_retraction is defined) %}
{% set length = params.LENGTH|default(client.unretract)|default(1.0)|float %}
{% set speed = params.SPEED|default(client.speed_unretract)|default(35) %}
{% set absolute_extrude = printer.gcode_move.absolute_extrude %}
{% if printer.toolhead.extruder != '' %}
{% if printer[printer.toolhead.extruder].can_extrude %}
{% if use_fw_retract %}
{% if length < 0 %}
G10
{% else %}
G11
{% else %}
M83
G1 E{length} F{(speed|float|abs) * 60}
{% if absolute_extrude %}
M82
{% else %}
RESPOND TYPE=echo MSG='{"\"%s\" not hot enough" % printer.toolhead.extruder}'
[gcode_macro _CLIENT_RETRACT]
description = Retracts, if the extruder is hot enough
gcode =
{% set client = printer[‘gcode_macro _CLIENT_VARIABLE’]|default({}) %}
{% set length = params.LENGTH|default(client.retract)|default(1.0)|float %}
{% set speed = params.SPEED|default(client.speed_retract)|default(35) %}
_CLIENT_EXTRUDE LENGTH=-{length|float|abs} SPEED={speed|float|abs}
[stepper_x]
step_pin = PC18
dir_pin = PB5
enable_pin = !PA9
microsteps = 128
rotation_distance = 40
endstop_pin = tmc5160_stepper_x:virtual_endstop
position_endstop = 0
position_max = 450
[tmc5160 stepper_x]
cs_pin = PD17
diag0_pin = ^!PD29
spi_bus = usart1
chain_position = 1
chain_length = 6
interpolate = False
run_current = 1
sense_resistor = 0.05
stealthchop_threshold = 0
driver_sgt = 0
[stepper_y]
step_pin = PC16
dir_pin = PD10
enable_pin = !PA9
microsteps = 128
endstop_pin = tmc5160_stepper_y:virtual_endstop
position_max = 450
[tmc5160 stepper_y]
cs_pin = PD17
diag1_pin = ^!PC17
chain_position = 2
chain_length = 6
interpolate = False
run_current = 1.0
driver_sgt = 0
step_pin = PC28
dir_pin = PA4
enable_pin = !PA9
microsteps = 64
rotation_distance = 8
endstop_pin = tmc5160_stepper_z:virtual_endstop
position_min = 0
position_max = 400
[tmc5160 stepper_z]
cs_pin = PD17
diag2_pin = ^!PD13
chain_position = 3
chain_length = 6
interpolate = False
run_current = 1.0
driver_sgt = 0
[stepper_z1]
step_pin = PC1
dir_pin = PA22
enable_pin = !PA9
microsteps = 64
[tmc5160 stepper_z1]
cs_pin = PD17
diag3_pin = ^!PC2
chain_position = 4
chain_length = 6
interpolate = False
run_current = 1.0
driver_sgt = 0
[stepper_z2]
step_pin = PC4
dir_pin = PC3
enable_pin = !PA9
microsteps = 64
[tmc5160 stepper_z2]
cs_pin = PD17
diag4_pin = ^!PD31
chain_position = 5
chain_length = 6
interpolate = False
run_current = 1.0
driver_sgt = 0
[adc_scaled vref_scaled]
vref_pin = PC0
vssa_pin = PC13
[mcu EBBCan]
serial = /dev/serial/by-id/usb-Klipper_rp2040_45474150538746FA-if00
[temperature_sensor EBB_NTC]
sensor_type = Generic 3950
sensor_pin = EBBCan:gpio28
[adxl345]
cs_pin = EBBCan:gpio1
spi_software_sclk_pin = EBBCan:gpio2
spi_software_mosi_pin = EBBCan:gpio0
spi_software_miso_pin = EBBCan:gpio3
axes_map = z,-y,x
[resonance_tester]
probe_points = 100, 100, 20
accel_chip = adxl345
step_pin = EBBCan:gpio18
dir_pin = !EBBCan:gpio19
enable_pin = !EBBCan:gpio17
microsteps = 16
rotation_distance = 33.500
nozzle_diameter = 0.400
filament_diameter = 1.750
heater_pin = EBBCan:gpio7
sensor_type = MAX31865
sensor_pin = EBBCan:gpio9
control = pid
pid_kp = 21.527
pid_ki = 1.063
pid_kd = 108.982
min_temp = 0
max_temp = 300
spi_software_sclk_pin = EBBCan:gpio10
spi_software_mosi_pin = EBBCan:gpio8
spi_software_miso_pin = EBBCan:gpio11
rtd_nominal_r = 1000
rtd_reference_r = 4300
rtd_num_of_wires = 2
[tmc2209 extruder]
uart_pin = EBBCan:gpio20
run_current = 0.650
[fan]
pin = EBBCan:gpio13
[heater_fan hotend_fan]
pin = EBBCan:gpio14
heater = extruder
heater_temp = 50.0
[neopixel hotend_rgb]
pin = EBBCan:gpio16
chain_count = 3
[heater_bed]
heater_pin = PA7
sensor_pin = vref_scaled:PC15
control = pid
pullup_resistor = 2200
pid_kp = 61.049
pid_ki = 2.339
pid_kd = 398.344
min_temp = 0
max_temp = 130
[temperature_sensor duet3_temp]
sensor_type = temperature_mcu
min_temp = 0
max_temp = 100
serial = /dev/serial/by-id/usb-Klipper_same70q20b_00313853315238323032303036303230-if00
[printer]
kinematics = corexy
max_velocity = 350
max_accel = 3000
Args: [‘/home/pi/klipper/klippy/klippy.py’, ‘/home/pi/printer_data/config/printer.cfg’, ‘-l’, ‘/home/pi/printer_data/logs/klippy.log’, ‘-I’, ‘/home/pi/printer_data/comms/klippy.serial’, ‘-a’, ‘/home/pi/printer_data/comms/klippy.sock’]
Git version: ‘v0.12.0-310-gef7534686’
Branch: master
Remote: origin
Tracked URL: GitHub - Klipper3d/klipper: Klipper is a 3d-printer firmware
CPU: 4 core ?
Python: ‘3.9.2 (default, Feb 28 2021, 17:03:44) \n[GCC 10.2.1 20210110]’
webhooks client 547894054816: {‘program’: ‘Moonraker’, ‘version’: ‘v0.9.3-0-g71f9e67’}
=============== Log rollover at Tue Oct 1 12:57:39 2024 ===============
Printer is halted
Attempting MCU ‘mcu’ reset
Attempting MCU ‘EBBCan’ reset
webhooks client 547894054816: Disconnected
Restarting printer
Start printer at Tue Oct 1 13:18:10 2024 (1727803090.3 1313.4)
[virtual_sdcard]
[pause_resume]
[display_status]
[respond]
gcode =
TURN_OFF_HEATERS
M106 S0
CANCEL_PRINT_BASE
[gcode_macro PAUSE]
gcode =
PAUSE_BASE
gcode =
{% else %}
{% else %}
{% if do_resume %}
_CLIENT_EXTRUDE
{% else %}
{% endfor %}
gcode =
gcode =
gcode =
gcode =
else False %}
_CLIENT_RETRACT
G90
{% else %}
gcode =
{% if length < 0 %}
G10
{% else %}
G11
{% else %}
M83
M82
{% else %}
gcode =
[stepper_x]
step_pin = PC18
dir_pin = PB5
enable_pin = !PA9
microsteps = 128
position_max = 450
[tmc5160 stepper_x]
cs_pin = PD17
spi_bus = usart1
chain_position = 1
chain_length = 6
interpolate = False
run_current = 1
diag0_pin = ^!PD29
driver_sgt = 0
[stepper_y]
step_pin = PC16
dir_pin = PD10
enable_pin = !PA9
microsteps = 128
position_max = 450
[tmc5160 stepper_y]
cs_pin = PD17
chain_position = 2
chain_length = 6
interpolate = False
run_current = 1.0
diag1_pin = ^!PC17
driver_sgt = 0
step_pin = PC28
dir_pin = PA4
enable_pin = !PA9
microsteps = 64
position_min = 0
position_max = 400
[tmc5160 stepper_z]
cs_pin = PD17
chain_position = 3
chain_length = 6
interpolate = False
run_current = 1.0
diag2_pin = ^!PD13
driver_sgt = 0
[stepper_z1]
step_pin = PC1
dir_pin = PA22
enable_pin = !PA9
microsteps = 64
cs_pin = PD17
chain_position = 4
chain_length = 6
interpolate = False
run_current = 1.0
diag3_pin = ^!PC2
driver_sgt = 0
[stepper_z2]
step_pin = PC4
dir_pin = PC3
enable_pin = !PA9
microsteps = 64
cs_pin = PD17
chain_position = 5
chain_length = 6
interpolate = False
run_current = 1.0
diag4_pin = ^!PD31
driver_sgt = 0
vref_pin = PC0
vssa_pin = PC13
[mcu EBBCan]
[adxl345]
axes_map = z,-y,x
[resonance_tester]
microsteps = 16
control = pid
pid_kp = 21.527
pid_ki = 1.063
pid_kd = 108.982
min_temp = 0
max_temp = 300
[tmc2209 extruder]
run_current = 0.650
[fan]
pin = EBBCan:gpio13
pin = EBBCan:gpio14
heater = extruder
heater_temp = 50.0
pin = EBBCan:gpio16
chain_count = 3
[heater_bed]
heater_pin = PA7
control = pid
pid_kp = 61.049
pid_ki = 2.339
pid_kd = 398.344
min_temp = 0
max_temp = 130
min_temp = 0
max_temp = 100
[printer]
kinematics = corexy
max_velocity = 350
max_accel = 3000
Config error
File “/home/pi/klipper/klippy/klippy.py”, line 130, in _connect
self.read_config()
File “/home/pi/klipper/klippy/klippy.py”, line 125, in read_config
m.add_printer_objects(config)
File “/home/pi/klipper/klippy/toolhead.py”, line 669, in add_printer_objects
config.get_printer().add_object(‘toolhead’, ToolHead(config))
File “/home/pi/klipper/klippy/toolhead.py”, line 269, in init
self.kin = mod.load_kinematics(self, config)
File “/home/pi/klipper/klippy/kinematics/corexy.py”, line 99, in load_kinematics
return CoreXYKinematics(toolhead, config)
File “/home/pi/klipper/klippy/kinematics/corexy.py”, line 12, in init
self.rails = [stepper.LookupMultiRail(config.getsection('stepper
’ + n))
’ + n))
File “/home/pi/klipper/klippy/stepper.py”, line 424, in LookupMultiRail
rail = PrinterRail(config, need_position_minmax,
File “/home/pi/klipper/klippy/stepper.py”, line 305, in init
self.add_extra_stepper(config)
File “/home/pi/klipper/klippy/stepper.py”, line 391, in add_extra_stepper
mcu_endstop = ppins.setup_pin(‘endstop’, endstop_pin)
File “/home/pi/klipper/klippy/pins.py”, line 118, in setup_pin
return pin_params[‘chip’].setup_pin(pin_type, pin_params)
File “/home/pi/klipper/klippy/extras/tmc.py”, line 495, in setup_pin
raise ppins.error(“tmc virtual endstop requires diag pin config”)
pins.error: tmc virtual endstop requires diag pin config
webhooks client 547894058816: New connection
webhooks client 547894058816: Client info {‘program’: ‘Moonraker’, ‘version’: ‘v0.9.3-0-g71f9e67’}
…Really hoping somebody here can help me. I’m not quite certain why I’m getting this error as I have the diag pins configured. I’m not quite a noob but not a pro either.
Thanks for any advice
Hello @OldGreyBeard !
Please upload as requested the klippy.log.
Copy&paste the printer.cfg just makes a huge mess and it is not usable.
For upload use:
Upload
okay sorry
klippy(3).log (28.9 KB)
Does anyone have any thoughts on why this is happening? Anything would be appreciated. I’m at a loss…
I actually figured this out. I was thinking that each diag had to have the corresponding driver #. When all of them must be diag1.
