Firmware Build issue Atmega328p
[o] Printer Model:
MCU / Printerboard: Atmega328p
Host / SBC Raspberry pi 3B+
[o] klippy.log
Tried to build firmware for the Atmega 328p. I found a issue on github for that specific problem, but i couldn´t find a solution to it. The issue is closed since 2021 and the problem is still present. There are a lot of workarounds but none of them work for me.
Has anybody a functioning solution to that?
make
  Creating symbolic link out/board
  Building out/autoconf.h
  Compiling out/src/sched.o
  Compiling out/src/command.o
  Compiling out/src/basecmd.o
  Compiling out/src/debugcmds.o
  Compiling out/src/initial_pins.o
  Compiling out/src/gpiocmds.o
  Compiling out/src/stepper.o
  Compiling out/src/endstop.o
  Compiling out/src/trsync.o
  Compiling out/src/adccmds.o
  Compiling out/src/spicmds.o
  Compiling out/src/i2ccmds.o
  Compiling out/src/pwmcmds.o
  Compiling out/src/buttons.o
  Compiling out/src/tmcuart.o
  Compiling out/src/neopixel.o
  Compiling out/src/pulse_counter.o
  Compiling out/src/lcd_st7920.o
  Compiling out/src/lcd_hd44780.o
  Compiling out/src/spi_software.o
  Compiling out/src/i2c_software.o
  Compiling out/src/thermocouple.o
  Compiling out/src/sensor_adxl345.o
  Compiling out/src/sensor_angle.o
  Compiling out/src/sensor_mpu9250.o
  Compiling out/src/sensor_lis2dw.o
  Compiling out/src/sensor_bulk.o
  Compiling out/src/avr/main.o
  Compiling out/src/avr/timer.o
  Compiling out/src/avr/gpio.o
  Compiling out/src/avr/adc.o
  Compiling out/src/avr/spi.o
  Compiling out/src/avr/i2c.o
  Compiling out/src/avr/hard_pwm.o
  Compiling out/src/avr/watchdog.o
  Compiling out/src/avr/serial.o
  Compiling out/src/generic/serial_irq.o
  Building out/compile_time_request.o
Version: v0.12.0-85-gd785b396a
  Linking out/klipper.elf
/usr/lib/gcc/avr/5.4.0/../../../avr/bin/ld: out/klipper.elf section `.text' will not fit in region `text'
/usr/lib/gcc/avr/5.4.0/../../../avr/bin/ld: address 0x800aa8 of out/klipper.elf section `.data' is not within region `data'
/usr/lib/gcc/avr/5.4.0/../../../avr/bin/ld: address 0x800c15 of out/klipper.elf section `.bss' is not within region `data'
/usr/lib/gcc/avr/5.4.0/../../../avr/bin/ld: region `text' overflowed by 5048 bytes
collect2: error: ld returned 1 exit status
make: *** [Makefile:72: out/klipper.elf] Error 1
See if Cannot build firmware for Arduino Uno - #7 by PCChazter helps
