Use:
G10 [(Retraction)] [S1 (Long Retraction)]
G11 [(Recover)]
M207 [T extruder no.] [F retract feedrate] [S retract length] [W swap retract length] [Z z hop height>]
M208 [T extruder no.] [F recover feedrate] [R swap recover feedrate] [S recover extra length] [w swap recover extra length]
In addition, M207 and M208 without a parameter will output a parameter.
In addition, there are two macros that are used when switching extruders:
gcode_macro switch_t0 and gcode_macro switch_t1, which must either be renamed or called from T0 (T1).
For more than 2 extruders, the variables in G11, M207 and M208 must be expanded. And create more gcode_macro switch_t(x)
I am interested in constructive feedback.
# tore1887
[gcode_macro P3] ; Firmware retraction, resett
M117
SET_GCODE_VARIABLE MACRO=G11 VARIABLE=e0_gog10 VALUE=True
SET_GCODE_VARIABLE MACRO=G11 VARIABLE=e1_gog10 VALUE=True
SET_GCODE_VARIABLE MACRO=G11 VARIABLE=e0_zhop VALUE=0.000
[gcode_macro G10] ; Firmware retraction, retract
description: G10 [S1 (Long Retraction)]
{% set extruderc = printer["gcode_macro switch_t0"].current %} ; Current extruder as a number
{% if printer[printer.toolhead.extruder].can_extrude and printer.toolhead.homed_axes == "xyz" %} ; Is Printer/Extruder ready
{% if printer["gcode_macro G11"]["e"~extruderc|string~"_gog10"] %} ; Can current extruder retract
{% set pose = printer.gcode_move.gcode_position.e %} ; Get current extruder position
{% if 'S' in params and params.S == "1" %} ; Swap retraction
{% set retr = printer["gcode_macro M207"]["e"~extruderc|string~"_w"] %} ; Get swap retraction amount
SET_GCODE_VARIABLE MACRO=G11 VARIABLE=e{extruderc}_swap VALUE=True ; Save swap status for retraction
{% else %}
{% set retr = printer["gcode_macro M207"]["e"~extruderc|string~"_s"] %} ; Get retraction amount
SET_GCODE_VARIABLE MACRO=G11 VARIABLE=e{extruderc}_swap VALUE=False ; Save swap status for retraction
G1 E{pose - retr} F{printer["gcode_macro M207"]["e"~extruderc|string~"_f"] } ; Retract
G92 E{pose} ; Set position
{% set posr = printer["gcode_macro M207"]["e"~extruderc|string~"_s"] %} ; Amount of retract
SET_GCODE_VARIABLE MACRO=G11 VARIABLE=e{extruderc}_retr VALUE={retr} ; Amount of retract save for unretract
{% set posz = printer.gcode_move.gcode_position.z %} ; Get current Z height
{% set posh = printer["gcode_macro M207"]["e"~extruderc|string~"_z"] %} ; Height to jump
{% set posj = (posz + posh)|round(5) %} ; Add
G0 Z{posj} ; Jump
G92 Z{posz} ; Set new position
SET_GCODE_VARIABLE MACRO=G11 VARIABLE=e{extruderc}_zhop VALUE={posh} ; Save for recovering
SET_GCODE_VARIABLE MACRO=G11 VARIABLE=e{extruderc}_gog10 VALUE=False ; Extruder E0 not ready to G10
{% else %}
M118 Extruder too cold or printer not homed!
[gcode_macro G11] ; Firmware retraction, recover
variable_e0_gog10: True ; Extruder0 ready to retract
variable_e1_gog10: True ; Extruder1 ready to retract
variable_e0_swap: False ; Extruder0 last retraction a swap retraction
variable_e1_swap: False ; Extruder1 last retraction a swap retraction
variable_e0_zhop: 0.0 ; Last Extruder0 jump height
variable_e1_zhop: 0.0 ; Last Extruder1 jump height
variable_e0_retr: 0.0 ; Last Extruder0 retraction
variable_e1_retr: 0.0 ; Last Extruder1 retraction
description: G11
gcode: ;
{% if printer[printer.toolhead.extruder].can_extrude %} ; Extruder warm
{% if not printer["gcode_macro G11"]["e"~extruderc|string~"_gog10"] %} ; If we are retracted, continue
{% set posh = printer["gcode_macro G11"]["e"~extruderc|string~"_zhop"] %} ; Height of the previous z hop
G0 Z{(posz - posh)|round(5)} ; Subtract, and jump down
SET_GCODE_VARIABLE MACRO=G11 VARIABLE=e{extruderc}_zhop VALUE=0 ; Current extruder zero Z-hop
{% set retr = printer["gcode_macro G11"]["e"~extruderc|string~"_retr"] %} ; Get last retraction amount
{% if printer["gcode_macro G11"]["e"~extruderc|string~"_swap"] %} ; Was last retraction a swap retraction
{% set extr = printer["gcode_macro M208"]["e"~extruderc|string~"_w"] %} ; Get swap additional recover lenght
{% set sped = printer["gcode_macro M208"]["e"~extruderc|string~"_r"] %} ; Get swap recover speed
{% else %} ;
{% set extr = printer["gcode_macro M208"]["e"~extruderc|string~"_s"] %} ; Get normal additional recover lenght
{% set sped = printer["gcode_macro M208"]["e"~extruderc|string~"_f"] %} ; Get recover speed
SET_GCODE_VARIABLE MACRO=G11 VARIABLE=e{extruderc}_swap VALUE=False ; Reset swap status for retraction
G1 E{pose + retr + extr} F{sped} ; Retract recover (unretract)
SET_GCODE_VARIABLE MACRO=G11 VARIABLE=e{extruderc}_gog10 VALUE=True ; Current extruder ready to G10
{% else %}
[gcode_macro M207] ; Firmware Retraction - retract setting
variable_e0_f: 2700 ; Retract feedrate
variable_e1_f: 2400
variable_e0_s: 2.0 ; Retract lenght
variable_e1_s: 4.0
variable_e0_w: 3.0 ; Retract swap lenght (multiextruder)
variable_e1_w: 5.0
variable_e0_z: 0.10 ; Z lift on retraction
variable_e1_z: 0.25
description: M207 [T extruder nr.] [F retract feedrate] [S retract length] [W swap retract length] [Z z hop height>]
gcode: ;
{% set extruderc = printer["gcode_macro switch_t0"].current %} ; Current extruder as a integer
{% if 'T' in params %} ;
{% set extrudert = params.T %} ;
{% endif %} ;
{% if 'F' in params %}
{% if (params.F|int <= 7200) and (params.F|int >= 300) %} ; Max 7200mm/min min 300mm/min
SET_GCODE_VARIABLE MACRO=M207 VARIABLE=e{extrudert}_f VALUE={params.F} ; Update M207 Tx F
{% else %}
SET_GCODE_VARIABLE MACRO=M207 VARIABLE=e{extruderc}_f VALUE={params.F} ; Update M207 F for current extruder
{% else %}
M118 Parameter 'F' out of range
{% if 'S' in params %}
{% if (params.S|int <= 10) and (params.S|int >= 0) %} ; Max 7200mm/min min 300mm/min
SET_GCODE_VARIABLE MACRO=M207 VARIABLE=e{extrudert}_s VALUE={params.S} ; Update M207 Tx S
{% else %}
SET_GCODE_VARIABLE MACRO=M207 VARIABLE=e{extruderc}_s VALUE={params.S} ; Update M207 S for current extruder
{% else %}
M118 Parameter 'S' out of range
{% if 'W' in params%}
{% if (params.W|float <= 10) and (params.W|float >= 0) %} ; Max 4mm min -2mm
SET_GCODE_VARIABLE MACRO=M207 VARIABLE=e{extrudert}_w VALUE={params.W} ; Update M207 Tx W
{% else %}
SET_GCODE_VARIABLE MACRO=M207 VARIABLE=e{extruderc}_w VALUE={params.W} ; Update M207 W for current extruder
{% else %}
M118 Parameter 'W' out of range
{% if 'Z' in params %}
{% if (params.Z|float <= 1) and (params.Z|float >= 0) %} ; Max 1mm min 0
SET_GCODE_VARIABLE MACRO=M207 VARIABLE=e{extrudert}_z VALUE={params.Z} ; Update M207 Tx Z
{% else %}
SET_GCODE_VARIABLE MACRO=M207 VARIABLE=e{extruderc}_z VALUE={params.Z} ; Update M207 Z for current extruder
{% else %}
M118 Parameter 'Z' out of range
{% if rawparams == "" %}
M118 Active extruder is {printer.toolhead.extruder}
M118 M207 T0 Speed {printer["gcode_macro M207"].e0_f} Lenght {printer["gcode_macro M207"].e0_s} Z-Hop {printer["gcode_macro M207"].e0_z}
M118 SWAP-Lenght {printer["gcode_macro M207"].e0_w}
M118 M208 T0 Speed {printer["gcode_macro M208"].e0_f} Recover-Extra {printer["gcode_macro M208"].e0_s}
M118 SWAP-Speed {printer["gcode_macro M208"].e0_r} SWAP-Recover-Extra {printer["gcode_macro M208"].e0_w}
M118
M118 M207 T1 Speed {printer["gcode_macro M207"].e1_f} Lenght {printer["gcode_macro M207"].e1_s} Z-Hop {printer["gcode_macro M207"].e1_z}
M118 SWAP-Lenght {printer["gcode_macro M207"].e1_w}
M118 M208 T1 Speed {printer["gcode_macro M208"].e1_f} Recover-Extra {printer["gcode_macro M208"].e1_s}
M118 SWAP-Speed {printer["gcode_macro M208"].e1_r} SWAP-Recover-Extra {printer["gcode_macro M208"].e1_w}
[gcode_macro M208] ; Firmware Retraction - unretract settingd
variable_e0_f: 2400 ; Recover feedrate
variable_e1_f: 2100
variable_e0_r: 2200 ; Swap recover feedrate (multiextruder)
variable_e1_r: 1900
variable_e0_s: 0.00 ; Additional recover lenght. Can be negativ to reduse recover lenght
variable_e1_s: 0.00
variable_e0_w: 0.00 ; Additional recover swap lenght. Can be negativ to reduse recover lenght (multiextruder)
variable_e1_w: 0.00
description: M208 [T extruder nr.] [F recover feedrate] [R swap recover feedrate] [S recover extra length] [w swap recover extra length]
gcode: ;
{% endif %} ;
{% if extrudert == "2" %} ; Extra code because I'm changing the second
{% set extrudert = "1" %} ; extruder between bowden and direct drive on my printer.
{% endif %} ; In Cura I have 3 extruders, and here I have to then correct T2 to T1.
SET_GCODE_VARIABLE MACRO=M208 VARIABLE=e{extrudert}_f VALUE={params.F} ; Update M208 Tx F
{% else %}
SET_GCODE_VARIABLE MACRO=M208 VARIABLE=e{extruderc}_f VALUE={params.F} ; Update M208 F for current extruder
{% else %}
M118 Parameter 'F' out of range, M208 {params.F}
{% if 'R' in params %}
{% if (params.R|int <= 7200) and (params.R|int >= 300) %} ; Max 7200mm/min min 300mm/min
SET_GCODE_VARIABLE MACRO=M208 VARIABLE=e{extrudert}_r VALUE={params.R} ; Update M208 Tx R
{% else %}
SET_GCODE_VARIABLE MACRO=M208 VARIABLE=e{extruderc}_r VALUE={params.R} ; Update M208 R for current extruder
{% else %}
M118 Parameter 'R' out of range
{% if 'S' in params%}
{% if (params.S|float <= 4) and (params.S|float >= -2) %} ; Max 4mm min -2mm
SET_GCODE_VARIABLE MACRO=M208 VARIABLE=e{extrudert}_s VALUE={params.S} ; Update M208 Tx R
{% else %}
SET_GCODE_VARIABLE MACRO=M208 VARIABLE=e{extruderc}_s VALUE={params.S} ; Update M208 S for current extruder
{% else %}
{% if (params.W|float <= 4) and (params.W|float >= -2) %} ; Max 4mm min -2mm
SET_GCODE_VARIABLE MACRO=M208 VARIABLE=e{extrudert}_w VALUE={params.W} ; Update M208 Tx W
{% else %}
SET_GCODE_VARIABLE MACRO=M208 VARIABLE=e{extruderc}_w VALUE={params.W} ; Update M208 S for current extruder
{% else %}
M118
[gcode_macro switch_t0] ; Called from macro T0
variable_current: 0 ; Current extruder
{% set old = printer["gcode_macro switch_t0"].current %} ; Current extruder as a number
{% set new = "0" %}
SET_GCODE_VARIABLE MACRO=switch_t0 VARIABLE=current VALUE={new} ; Set current extruder
{% if printer["gcode_macro G11"]["e"~old|string~"_zhop"] > 0 or printer["gcode_macro G11"]["e"~new|string~"_zhop"] > 0 %}
M118 T0 Jumping OLd hight {posz}
; Remove any old extruder z_hop Add any new E1 z_hop
G0 Z{posz - printer["gcode_macro G11"]["e"~old|string~"_zhop"] + printer["gcode_macro G11"]["e"~new|string~"_zhop"]}
M118 New Hight
G92 Z{posz}
[gcode_macro switch_t1] ; Called from macro from T1
{% set new = "1" %}
M118 T1 Jumping
G92 Z{posz}
