Printer Model: Flsun qqs pro
MCU / Printerboard: FlSUN Hispeed v1
klippy(3).log (79.1 KB)
config
include mainsail.cfg]
restart_method: command
baud: 250000
[printer]
kinematics: delta
max_velocity: 500
max_accel: 2000
max_z_velocity: 200
minimum_z_position: -5
delta_radius: 130
[stepper_a]
step_pin: PE3
dir_pin: PE2
enable_pin: !PE4
rotation_distance: 32
endstop_pin: PA15
homing_speed: 60
position_endstop: 370
arm_length: 280.0
[stepper_b]
step_pin: PE0
dir_pin: PB9
enable_pin: !PE1
endstop_pin: PA12
[stepper_c]
step_pin: PB5
dir_pin: PB4
enable_pin: !PB8
endstop_pin: PC4
[probe]
pin: !PA11
x_offset: 0
y_offset: 0
#z_offset: 10
samples: 3
samples_result: average
sample_retract_dist: 5
[delta_calibrate]
radius: 120
horizontal_move_z: 10
step_pin: PD6
dir_pin: !PD3
enable_pin: !PB3
rotation_distance: 9
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PC3
sensor_pin: PC1
control: pid
pid_Kp: 14.529
pid_Ki: 0.557
pid_Kd: 94.802
min_extrude_temp: 180
min_temp: 0
max_temp: 260
[tmc2209 stepper_a]
uart_pin: PA8
uart_address: 1
interpolate: True
run_current: .850
hold_current: .500
stealthchop_threshold: 0
[tmc2209 stepper_b]
uart_pin: PA8
uart_address: 2
interpolate: True
run_current: .850
hold_current: .500
[tmc2209 stepper_c]
uart_pin: PA8
uart_address: 3
interpolate: True
run_current: .850
hold_current: .500
[tmc2209 extruder]
uart_pin: PA8
uart_address: 0
interpolate: True
run_current: .850
hold_current: .500
[heater_bed]
heater_pin: PA0
sensor_pin: PC0
control: pid
pid_Kp: 325.10
pid_Ki: 63.35
pid_Kd: 417.10
min_temp: 0
max_temp: 150
[fan]
pin: PB1
kick_start_time: 0.200
Optional: Bed mesh leveling - only use if the PROBE_ACCURACY
command outputs a range value < 0.025 mm
[bed_mesh]
speed: 50
horizontal_move_z: 35
mesh_radius: 100
mesh_origin: 0,0
round_probe_count: 5
algorithm: lagrange
Optional: End-stop style filament sensor
#[filament_switch_sensor Filament]
#pause_on_runout: True
#switch_pin: PA4
Optional: BL Touch Probe - comment out [probe] section if using this
#[bltouch]
#sensor_pin: PA11
#control_pin: PA8
#stow_on_each_sample: True
#set_output_mode: 5V
#x_offset: 3
#y_offset: -36
#z_offset: -2.3
#samples: 3
#sample_retract_dist: 5
#samples_result: average
This is the path where your g-code files will be uploaded to in the
rasbperry pi
[virtual_sdcard]
path: ~/printer_data/gcodes
[display_status]
[pause_resume]
This macro should be called at the ‘start g-code’ part
of your slicer and you would put all the start g-code here
instead so that you don’t have to re-slice everytime you
have to edit the commands
[gcode_macro START_PRINT]
#SET_GCODE_OFFSET Z_ADJUST=-0.1 MOVE=1 # sets the z-offset
This macro should be called at the ‘end g-code’ part
of your slicer and like the macro above, you would
also put all of your end g-code here for the same reason as above
[gcode_macro END_PRINT]
SET_GCODE_OFFSET Z_ADJUST=0 # resets the z-offset (otherwise, )
Pause print macro
[gcode_macro PAUSE]
rename_existing: BASE_PAUSE
SAVE_GCODE_STATE NAME=PAUSE_state
BASE_PAUSE
G91
G1 E-{params.E|default(1)} F2100 ; change 1 to your default retraction distance
G1 Z{params.Z|default(10)} ; change 10 to your Z parking position
G90
G1 X{params.X|default(230)} Y{params.Y|default(230)} F6000 ; change 230 to your X and Y parking postiob
Resume print macro
[gcode_macro RESUME]
rename_existing: BASE_RESUME
G91
G1 E{params.E|default(1)} F2100 ; change 1 to your default retraction distance
G90
RESTORE_GCODE_STATE NAME=PAUSE_state MOVE=1
BASE_RESUME
Cancel print macro
[gcode_macro CANCEL_PRINT]
rename_existing: BASE_CANCEL_PRINT
TURN_OFF_HEATERS
CLEAR_PAUSE
SDCARD_RESET_FILE
BASE_CANCEL_PRINT
## <---------------------- SAVE_CONFIG ---------------------->
## DO NOT EDIT THIS BLOCK OR BELOW. The contents are auto-generated.
## [probe]
#*# z_offset = 10.225
HI ! I upgrade my flsun qqs pro whis tmc2209 lerdge , I want to use 1 wire configurarion . I did everything as on the site Upgrading FLSUN QQ-S Pro to TMC2209 – Angel's Personal Blog (Photo 1).In drivers i solder J3 pin up side with center (Photo 2) and connect uart port like .check all connections with a multimeter. Get the error :
" Unable to read tmc uart ‘stepper_a’ register IFCNT
Printer is shutdown ‘’
What have i done wrong ?
