Printer Model: Voron v0.2
MCU / Printerboard: BTT SKR Pico
klippy.log (258.8 KB)
Klipper Version: 0.11.0-277
Using either FORCE_MOVE or SET_KINEMATIC_POSITION from a non-homed state causes an exception in the tmc driver.
Relevant section from the log:
SET_KINEMATIC_POSITION pos=0.000,0.000,0.000
['x']
Unhandled exception during run
File "/home/biqu/klipper/klippy/klippy.py", line 217, in run
self.reactor.run()
File "/home/biqu/klipper/klippy/reactor.py", line 292, in run
g_next.switch()
File "/home/biqu/klipper/klippy/reactor.py", line 340, in _dispatch_loop
timeout = self._check_timers(eventtime, busy)
File "/home/biqu/klipper/klippy/reactor.py", line 158, in _check_timers
t.waketime = waketime = t.callback(eventtime)
File "/home/biqu/klipper/klippy/reactor.py", line 48, in invoke
res = self.callback(eventtime)
File "/home/biqu/klipper/klippy/extras/tmc.py", line 388, in <lambda>
cb = (lambda ev: self._do_enable(print_time))
File "/home/biqu/klipper/klippy/extras/tmc.py", line 354, in _do_enable
self._init_registers()
File "/home/biqu/klipper/klippy/extras/tmc.py", line 265, in _init_registers
for reg_name, val in self.fields.registers.items():
RuntimeError: OrderedDict mutated during iteration
