Getting attributes in macros
Printer Model: Customized E3NG
MCU / Printerboard: BTT Pico x2
Host / SBC OrangePi3Zero
klippy (24).log (1.5 MB)
I have a [extruder_stepper extruder1] section defined in my printer.cfg, and it has a rotation_distance of 22.6789511 defined there.
If I try to use this line in a macro:
{% set oldrot = printer.configfile.settings.extruder1.rotation_distance|float %}
I’ll basically end up with the error:
gcode.CommandError: Error evaluating ‘gcode_button TooFar:press_gcode’: jinja2.exceptions.UndefinedError: ‘dict object’ has no attribute ‘extruder1’
If I pull it out of the main extruder, ie:
{% set oldrot = printer.configfile.settings.extruder.rotation_distance|float %}
It works as expected. Am I trying to do something that isn’t supported?
I’m trying to write some runtime turtleneck type filament buffer macros.
Thanks.
I would expect that this should be printer.configfile.settings['extruder_stepper extruder1'].rotation_distance since that’s what you said you wanted to access, not a section named extruder1.
That did it! Thank you very much.
