Handling timers during tick wrap
My trip through the Klipper MCU code continues.
Now, I am trying to understand how Klipper handles ordering of the timers list, especially when wake times wrap around.
From what I can understand, Klipper maintain a singly-linked list of timers where each successive timer has a higher wake time than the previous one. It uses the wake times to decide where to insert the new timer (edited for brevity):
static void __always_inline
insert_timer(struct timer *pos, struct timer *t, uint32_t waketime)
    struct timer *prev;
    for (;;) {
        prev = pos;
        pos = pos->next;
        if (timer_is_before(waketime, pos->waketime))
            break;
    t->next = pos;
    prev->next = t;
Now, suppose that the current clock tick value is close to (1 << 32) - 1. So, it’s possible that waketime (the new time tha a timer needs to be woken at) has wrapped around. So, waketime will be before pos->waketime.
In this case, the new timer will be inserted before pos. However, it is supposed to trigger after pos.
The sched_timer_dispatch() function executes a single timer at a time (the one at the head of the list). So, on the next call, it will execute t (the newly inserted timer) instead of pos.
So, how does Klpper ensure that timers are order properly when the clock and wake times are around the wrap point?
Timers are always added in the future, if not then Timer Too Close happens.
Also, there is a timer_is_before().
Rescheduling is a little more tricky, it happens inside timer_dispatch_many.
Generally speaking, if the timer is rescheduled as the next one, it will be executed as the next one.
If timers a lagging behind, they will be executed “faster”.
If they fall too far behind - “Rescheduled timer in the past” happens.
I understand that they are always inserted in the future but the value of the future is not monotonically increasing. What happens when the waketime wraps?
timer_is_before() handles that, as long as the difference is less than (1<<31), we can easily compare timers.
So, for us, time is always in the future.
If it is in the too far future > (1<<31), it is a wrap, and something will brake.
(and we never schedule or reschedule in such far future).
I think that you are misunderstanding me:
Suppose that the current tick value is (1 << 32) - 20. There is a timer that is scheduled for (1 << 32) - 10 (timer A). A timer (timer B) is executed, which reschedules itself to wake up at current_tick + 50. So, the new wake time in absolute ticks is 30.
When sched_add_timer() is called to add timer B, it compares against timer A and finds that timer_is_before(B, A) is true. So, it inserts B before A.
As a result, A executes much, much later that it should because the ticks have to wrap all the way around to (1 << 32) - 10.
The new B timer value is 30.
The A timer value is 4294967286.
// Return true if time1 is before time2.  Always use this function to
// compare times as regular C comparisons can fail if the counter
// rolls over.
uint8_t
timer_is_before(uint32_t time1, uint32_t time2)
    return (int32_t)(time1 - time2) < 0;
#include <stdio.h>
#include <stdint.h>
#include <limits.h>
int main() {
    uint32_t A = UINT_MAX - 10;
    uint32_t B = 30;
    printf("%i\n", (int32_t)(B-A));
Output:
41
Which is not less than 0, so false, so B is in the future.
Well, this is embarrassing!!
Signed/unsigned math gets me again. Thanks for setting me straight. I’ve been struggling to understand how Klipper is not crashing and burning :smiley:
Using your example code:
#include <stdio.h>
#include <stdint.h>
#include <limits.h>
int main() {
    uint32_t A = 2221580162;
    uint32_t B = 76474112;
    printf("%i\n", (int32_t)(B - A));
Output:
-2145106050
In this example, A is not very close to UINT_MAX but the comparison should still hold, should it?
Well, everything is correct here, B is before A.
As I said, as long as the difference is less than (1<<31) there is no wrap.
If you schedule the timer in the future in such way, that it is more than (1<<31) (what you did here), it is happen to be in the past.
