Printer Model: a8
MCU / Printerboard: skr1.4, anet a8 board, rap
If you use save_gcode_state, do you not save the gcode for the z-direction?
And I wonder if that command works only during file printing
When restoring_gcode_state is executed, the x and y axes return, but the z-axis does not return
And I wonder if it’s relative coordinates or absolute coordinates when you return
Please understand even if it is strange because it is a question translated by a translator
