Help with TEST_RESONANCES,
Printer Model: Anet E12
MCU / Printerboard: Anet 1.0 board
Host / SBC: NEC LS550 Laptop 6gb ram
klippy.log |
klippy (1).zip (3.9 MB)
I Trying to calibrate input shapers using TEST_RESONANCES
but Klipper gives me an error
I’ve tried solving the problem from past posts(including github), but that didn’t help
“Internal error on command:“TEST_RESONANCES”
Printer is shutdown”
“name ‘thpos’ is not defined”
Problem solved, I wasn’t looking at the log carefully, I changed
X, Y = thpos[:2] to
X, Y = tpos[:2]
and everything worked
