Hi, I just upgraded my Ender 3 Pro to a Hero Me Gen 6 setup. This upgrade causes the nozzle to move -9 mm on the Y axis. How can I set this up in the config files? Otherwise all my prints will be 9mm off-center on the Y axis. Thanks!
Adjust position_endstop on the Y axis
I set
position_endstop: -9
and I’m getting this error now:
position_endstop in section ‘stepper_y’ must be between position_min and position_max
I guess the bed can’t move past the endstop which is logical. Should I also adjust position_min?
Yes, it should match position_endstop
Awesome! It’s a lot clearer for me now. Thank you!
