How to best implement the Eddy sensor and EddyTap function
Printer Model: Voron 1.8
MCU / Printerboard: SKR mini e3 v3
Host / SBC Pi4
klippy.zip (24.3 KB)
I have an BTT Eddy Coil sensor, and have been using the EddyNG setup with good results. I decided to migrate back to mainline klipper now that Eddy Tap funcions are integrated.
I did encounter a few problems setting up the ldc sensor and calibrating the sensor, which I had to workaround(and did not document) and ultimately have a succssful tap with adequate accuracy and can rapid_scan.
I am curious about how to best implement the Klipper Tap function into my print start macro and how to use the macros supplied in the Eddy Config doc.
-do I use the command “Probe method=tap” to set the final z offset, when the printer is warmed up right before printing?
-what is the use case for the macros in the Eddy Config doc?
Thanks for your time
Shortly speaking, Eddy coil does not have thermistor, so to make use of data not from the tap at different temperatures, you have to somehow cancel the thermal drift.
Technically you have now at least 2 probes, one probe, probes with the nozzle, second one does proximity estimation based on the “scan” and calibration data from the config.
Tap allows to get some reliable/repeatable point in a space, so one can compare PROBE, PROBE METHOD=scan, PROBE METHOD=rapid_scan against it.
In ideal world, all probe modes would output the same value at the same spot.
PROBE commands does not alter anything, including the z_offset, probe commands, well, do the probe.
How I think, it should work:
  1. You configure tap to get some reliable “tap”
  2. You print with SET_Z_FROM_PROBE METHOD=tap + BED_MESH_CALIBRATE MEHTOD=tap, to get the idea of tap offset, if it is here.
  3. One can automate setting of G-Code Z Offset after the tap, because it would be a constant value at a specific speed.
Then, when you have reliable tap data, and you know that tap provides you with the TRUE zero reference plane.
One can proceed here: probe_eddy_current: runtime calibration curve adjustment by nefelim4ag · Pull Request #7179 · Klipper3d/klipper · GitHub
And with knowledge of “tap” offset,
one can then set kinematic state to the correct “zero” reference, and by measuring the second (scan) probe at the same spot, measure the thermal drift offset.
Hope that helps,
-Timofey
UPD at 05.07.2026: Eddy: compensate bed_mesh with tap
Do you mean here to use that Tap method to generate a bed mesh? I am hoping to continue with a rapid_scan bed mesh and utilize the Tap function to set a final z-offset when the printer is at printing temperature, which I think is what you are describing otherwise.
I just got this setup and working thanks to Timofey’s macro. I think it will answer your question and potentially help others to use this method if I describe my observations of how the macro works:
First, the macro taps a given point, and set’s the printer’s z to the “true” 0 where the nozzle contacts the bed (assuming you have set up tap successfully per the documentation).
Next the macro moves the tool head to scan the same point without contact. (important that your offsets are correct here).
Then it finds the difference between the tap and scan and saves that as a G Code Z offset. A few things to note here:
  • This is the same kind of Z offset used when adjusting it from fluid/mainsail for fine tuning your first layer. It was displayed just the same in mainsail for me.
  • Its worth noting that this is only valid for this temperature and subsequent bed mesh. It is likely to change slightly at different temps.
  • If you try to do a paper test at this point (before the mesh) the results will be shifted by the offset.
The last and crucial step is performing a bed mesh using the scan or rapid scan method. As the coil is now calibrated to the right distance from the nozzle tap (thanks to the G Code Z Offset), a loaded bed mesh created by the scan will essentially cancel out the G Code Z offset.
This last part tripped me up for a while, as the bed mesh will appear to be shifted. It is indeed shifted and should match very closely to that same G Code Z offset value found as the difference between the tap and scan.
In my case, probing in the middle of my bed is generally the low point. The mesh after running the macro showed a minimum that corresponded near perfectly to the offset. At this point doing a paper test is a good confirmation that you are good to go. It should occur right around absolute Z 0.1mm.
One other mention, the scan will vary with coil temperature. Ideally you want the coil to remain the same temperature from the tap until the mesh is complete.
