hello
i am trying to install klipper.
i get error
n of function ‘PyType_Ready’ [-Wimplicit-function-declaration]
if (PyType_Ready(&dl_type) < 0)
c/_cffi_backend.c:7570:19: warning: ‘return’ with no value, in function returning non-void
#define INITERROR return
c/_cffi_backend.c:7605:9: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:7573:1: note: declared here
init_cffi_backend(void)
c/_cffi_backend.c:7607:9: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:7609:9: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:7611:9: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:7613:9: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:7615:9: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:7617:9: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:7619:9: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:7621:9: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:7624:11: warning: assignment to ‘int *’ from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
v = PyText_FromString("_cffi_backend");
c/_cffi_backend.c:7625:26: warning: implicit declaration of function ‘PyDict_SetItemString’; did you mean ‘PyText_FromString’? [-Wimplicit-function-declaration]
if (v == NULL || PyDict_SetItemString(CData_Type.tp_dict,
PyText_FromString
c/_cffi_backend.c:7625:57: error: request for member ‘tp_dict’ in something not a structure or union
c/_cffi_backend.c:7627:13: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:7628:11: warning: assignment to ‘int *’ from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
v = PyText_FromString("");
c/_cffi_backend.c:7629:57: error: request for member ‘tp_dict’ in something not a structure or union
c/_cffi_backend.c:7631:13: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:148:6: warning: implicit declaration of function ‘PyCObject_FromVoidPtr’; did you mean ‘PyText_FromFormat’? [-Wimplicit-function-declaration]
(PyCObject_FromVoidPtr(pointer, destructor))
c/_cffi_backend.c:7636:9: note: in expansion of macro ‘PyCapsule_New’
v = PyCapsule_New((void *)cffi_exports, “cffi”, NULL);
c/_cffi_backend.c:7636:7: warning: assignment to ‘int *’ from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
c/_cffi_backend.c:7637:22: warning: implicit declaration of function ‘PyModule_AddObject’ [-Wimplicit-function-declaration]
if (v == NULL || PyModule_AddObject(m, “_C_API”, v) < 0)
c/_cffi_backend.c:7638:9: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:7640:7: warning: assignment to ‘int *’ from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
v = PyText_FromString(CFFI_VERSION);
c/_cffi_backend.c:7642:9: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:7644:9: warning: implicit declaration of function ‘PyModule_AddIntConstant’ [-Wimplicit-function-declaration]
if (PyModule_AddIntConstant(m, “FFI_DEFAULT_ABI”, FFI_DEFAULT_ABI) < 0 ||
c/_cffi_backend.c:7658:7: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:7664:13: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:7668:42: error: ‘PyObject’ undeclared (first use in this function); did you mean ‘LibObject’?
if (PyModule_AddObject(m, “buffer”, (PyObject *)&MiniBuffer_Type) < 0)
LibObject
c/_cffi_backend.c:7668:52: error: expected expression before ‘)’ token
c/_cffi_backend.c:7668:51: error: invalid operands to binary * (have ‘int *’ and ‘int *’)
c/_cffi_backend.c:7669:9: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:7673:9: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:7676:9: note: in expansion of macro ‘INITERROR’
INITERROR;
c/_cffi_backend.c:7678:9: warning: implicit declaration of function ‘init_ffi_lib’; did you mean ‘init_cffi_tls’? [-Wimplicit-function-declaration]
if (init_ffi_lib(m) < 0)
init_cffi_tls
c/_cffi_backend.c:7679:9: note: in expansion of macro ‘INITERROR’
INITERROR;
In file included from c/_cffi_backend.c:7552:
At top level:
c/cffi1_module.c:132:18: warning: ‘_my_Py_InitModule’ defined but not used [-Wunused-function]
static PyObject *_my_Py_InitModule(char *module_name)
In file included from c/cffi1_module.c:18,
c/cdlopen.c:99:12: warning: ‘_cdl_realize_global_int’ defined but not used [-Wunused-function]
static int _cdl_realize_global_int(struct _cffi_getconst_s *gc)
c/cdlopen.c:89:23: warning: ‘cdl_opcode’ defined but not used [-Wunused-function]
static _cffi_opcode_t cdl_opcode(char *src)
In file included from c/cffi1_module.c:17,
c/lib_obj.c:626:19: warning: ‘lib_internal_new’ defined but not used [-Wunused-function]
static LibObject *lib_internal_new(FFIObject *ffi, const char *module_name,
c/lib_obj.c:583:20: warning: ‘lib_methods’ defined but not used [-Wunused-variable]
static PyMethodDef lib_methods[] = {
c/lib_obj.c:480:18: warning: ‘_lib_dict’ defined but not used [-Wunused-function]
static PyObject *_lib_dict(LibObject *lib)
c/lib_obj.c:451:18: warning: ‘_lib_dir1’ defined but not used [-Wunused-function]
static PyObject *_lib_dir1(LibObject *lib, int ignore_global_vars)
c/lib_obj.c:115:18: warning: ‘lib_build_cpython_func’ defined but not used [-Wunused-function]
static PyObject *lib_build_cpython_func(LibObject *lib,
c/lib_obj.c:109:18: warning: ‘lib_repr’ defined but not used [-Wunused-function]
static PyObject *lib_repr(LibObject *lib)
c/lib_obj.c:91:13: warning: ‘lib_dealloc’ defined but not used [-Wunused-function]
static void lib_dealloc(LibObject *lib)
c/lib_obj.c:54:18: warning: ‘_cpyextfunc_type’ defined but not used [-Wunused-function]
static PyObject *_cpyextfunc_type(LibObject *lib, struct CPyExtFunc_s *exf)
In file included from c/cffi1_module.c:16,
c/cglob.c:99:18: warning: ‘cg_addressof_global_var’ defined but not used [-Wunused-function]
static PyObject *cg_addressof_global_var(GlobSupportObject *gs)
c/cglob.c:83:18: warning: ‘read_global_var’ defined but not used [-Wunused-function]
static PyObject *read_global_var(GlobSupportObject *gs)
c/cglob.c:21:21: warning: ‘GlobSupport_Type’ defined but not used [-Wunused-variable]
static PyTypeObject GlobSupport_Type = {
c/cglob.c:14:13: warning: ‘glob_support_dealloc’ defined but not used [-Wunused-function]
static void glob_support_dealloc(GlobSupportObject *gs)
In file included from c/cffi1_module.c:15,
c/ffi_obj.c:1133:20: warning: ‘ffi_getsets’ defined but not used [-Wunused-variable]
static PyGetSetDef ffi_getsets[] = {
c/ffi_obj.c:1102:20: warning: ‘ffi_methods’ defined but not used [-Wunused-variable]
static PyMethodDef ffi_methods[] = {
c/ffi_obj.c:977:13: warning: ‘_free_init_once_lock’ defined but not used [-Wunused-function]
static void _free_init_once_lock(void *lock)
c/ffi_obj.c:588:18: warning: ‘_combine_type_name_l’ defined but not used [-Wunused-function]
static PyObject *_combine_type_name_l(CTypeDescrObject *ct,
c/ffi_obj.c:148:26: warning: ‘_ffi_bad_type’ defined but not used [-Wunused-function]
static CTypeDescrObject *_ffi_bad_type(FFIObject *ffi, const char *input_text)
c/ffi_obj.c:95:18: warning: ‘ffi_fetch_int_constant’ defined but not used [-Wunused-function]
static PyObject *ffi_fetch_int_constant(FFIObject *ffi, const char *name,
c/ffi_obj.c:65:13: warning: ‘ffi_dealloc’ defined but not used [-Wunused-function]
static void ffi_dealloc(FFIObject *ffi)
c/ffi_obj.c:1138:21: warning: ‘FFI_Type’ defined but not used [-Wunused-variable]
static PyTypeObject FFI_Type = {
In file included from c/cffi1_module.c:3,
c/realize_c_type.c:82:12: warning: ‘init_builder_c’ defined but not used [-Wunused-function]
static int init_builder_c(builder_c_t *builder,
c/realize_c_type.c:13:39: warning: ‘g_ct_chararray’ defined but not used [-Wunused-variable]
static CTypeDescrObject *g_ct_voidp, *g_ct_chararray;
c/realize_c_type.c:13:26: warning: ‘g_ct_voidp’ defined but not used [-Wunused-variable]
In file included from c/cffi1_module.c:2,
c/parse_c_type.c:837:5: warning: ‘parse_c_type’ defined but not used [-Wunused-function]
int parse_c_type(struct _cffi_parse_info_s *info, const char *input)
c/_cffi_backend.c:7176:12: warning: ‘_testfunc23’ defined but not used [-Wunused-function]
static int _testfunc23(char *p)
c/_cffi_backend.c:7166:29: warning: ‘_testfunc22’ defined but not used [-Wunused-function]
static struct _testfunc22_s _testfunc22(struct _testfunc22_s s1,
c/_cffi_backend.c:7151:12: warning: ‘_testfunc21’ defined but not used [-Wunused-function]
static int _testfunc21(struct _testfunc21_s inlined)
c/_cffi_backend.c:7145:14: warning: ‘_testfunc20’ defined but not used [-Wunused-function]
static short _testfunc20(struct _testfunc7_s *ptr)
c/_cffi_backend.c:7136:20: warning: ‘_testfunc19’ defined but not used [-Wunused-function]
static long double _testfunc19(long double x, int count)
c/_cffi_backend.c:7131:12: warning: ‘_testfunc18’ defined but not used [-Wunused-function]
static int _testfunc18(struct _testfunc17_s *ptr)
c/_cffi_backend.c:7123:29: warning: ‘_testfunc17’ defined but not used [-Wunused-function]
static struct _testfunc17_s _testfunc17(int n)
c/_cffi_backend.c:7114:29: warning: ‘_testfunc16’ defined but not used [-Wunused-function]
static struct _testfunc16_s _testfunc16(int n)
c/_cffi_backend.c:7105:29: warning: ‘_testfunc15’ defined but not used [-Wunused-function]
static struct _testfunc15_s _testfunc15(int n)
c/_cffi_backend.c:7097:29: warning: ‘_testfunc14’ defined but not used [-Wunused-function]
static struct _testfunc14_s _testfunc14(int n)
c/_cffi_backend.c:7087:29: warning: ‘_testfunc13’ defined but not used [-Wunused-function]
static struct _testfunc13_s _testfunc13(int n)
c/_cffi_backend.c:7079:29: warning: ‘_testfunc12’ defined but not used [-Wunused-function]
static struct _testfunc12_s _testfunc12(int n)
c/_cffi_backend.c:7070:29: warning: ‘_testfunc11’ defined but not used [-Wunused-function]
static struct _testfunc11_s _testfunc11(int n)
c/_cffi_backend.c:7061:28: warning: ‘_testfunc10’ defined but not used [-Wunused-function]
static struct _testfunc7_s _testfunc10(int n)
c/_cffi_backend.c:7046:12: warning: ‘_testfunc9’ defined but not used [-Wunused-function]
static int _testfunc9(int num, …)
c/_cffi_backend.c:7042:14: warning: ‘_testfunc7’ defined but not used [-Wunused-function]
static short _testfunc7(struct _testfunc7_s inlined)
c/_cffi_backend.c:7035:13: warning: ‘_testfunc6’ defined but not used [-Wunused-function]
static int *_testfunc6(int *x)
c/_cffi_backend.c:7031:13: warning: ‘_testfunc5’ defined but not used [-Wunused-function]
static void _testfunc5(void)
c/_cffi_backend.c:7027:14: warning: ‘_testfunc4’ defined but not used [-Wunused-function]
static float _testfunc4(float a, double b)
c/_cffi_backend.c:7023:15: warning: ‘_testfunc3’ defined but not used [-Wunused-function]
static double _testfunc3(float a, double b)
c/_cffi_backend.c:7015:13: warning: ‘_testfunc1’ defined but not used [-Wunused-function]
static long _testfunc1(int a, long b)
c/_cffi_backend.c:7011:13: warning: ‘_testfunc0’ defined but not used [-Wunused-function]
static char _testfunc0(char a, char b)
c/_cffi_backend.c:6192:19: warning: ‘direct_sizeof_cdata’ defined but not used [-Wunused-function]
static Py_ssize_t direct_sizeof_cdata(CDataObject *cd)
c/_cffi_backend.c:5925:13: warning: ‘invoke_callback’ defined but not used [-Wunused-function]
static void invoke_callback(ffi_cif *cif, void *result, void **args,
c/_cffi_backend.c:5475:13: warning: ‘fb_cat_name’ defined but not used [-Wunused-function]
static void fb_cat_name(struct funcbuilder_s *fb, const char *piece,
c/_cffi_backend.c:5257:18: warning: ‘fb_fill_type’ defined but not used [-Wunused-function]
static ffi_type *fb_fill_type(struct funcbuilder_s *fb, CTypeDescrObject *ct,
c/_cffi_backend.c:4826:12: warning: ‘complete_sflags’ defined but not used [-Wunused-function]
static int complete_sflags(int sflags)
c/_cffi_backend.c:4217:20: warning: ‘dl_methods’ defined but not used [-Wunused-variable]
static PyMethodDef dl_methods[] = {
c/_cffi_backend.c:4104:12: warning: ‘dl_check_closed’ defined but not used [-Wunused-function]
static int dl_check_closed(DynLibObject *dlobj)
c/_cffi_backend.c:4099:18: warning: ‘dl_repr’ defined but not used [-Wunused-function]
static PyObject *dl_repr(DynLibObject *dlobj)
c/_cffi_backend.c:4091:13: warning: ‘dl_dealloc’ defined but not used [-Wunused-function]
static void dl_dealloc(DynLibObject *dlobj)
c/_cffi_backend.c:3503:1: warning: ‘cdata_iter’ defined but not used [-Wunused-function]
cdata_iter(CDataObject *cd)
c/_cffi_backend.c:3465:1: warning: ‘cdataiter_dealloc’ defined but not used [-Wunused-function]
cdataiter_dealloc(CDataIterObject *it)
c/_cffi_backend.c:3454:1: warning: ‘cdataiter_next’ defined but not used [-Wunused-function]
cdataiter_next(CDataIterObject *it)
c/_cffi_backend.c:3252:20: warning: ‘cdata_methods’ defined but not used [-Wunused-variable]
static PyMethodDef cdata_methods[] = {
c/_cffi_backend.c:3246:25: warning: ‘CDataOwn_as_mapping’ defined but not used [-Wunused-variable]
static PyMappingMethods CDataOwn_as_mapping = {
c/_cffi_backend.c:3240:25: warning: ‘CData_as_mapping’ defined but not used [-Wunused-variable]
static PyMappingMethods CData_as_mapping = {
c/_cffi_backend.c:3206:24: warning: ‘CData_as_number’ defined but not used [-Wunused-variable]
static PyNumberMethods CData_as_number = {
c/_cffi_backend.c:2828:26: warning: ‘_get_ct_int’ defined but not used [-Wunused-function]
static CTypeDescrObject *_get_ct_int(void)
c/_cffi_backend.c:2334:1: warning: ‘cdata_length’ defined but not used [-Wunused-function]
cdata_length(CDataObject *cd)
c/_cffi_backend.c:2316:13: warning: ‘cdata_hash’ defined but not used [-Wunused-function]
static long cdata_hash(CDataObject *v)
c/_cffi_backend.c:2208:18: warning: ‘cdata_long’ defined but not used [-Wunused-function]
static PyObject *cdata_long(CDataObject *cd)
c/_cffi_backend.c:2140:12: warning: ‘cdata_nonzero’ defined but not used [-Wunused-function]
static int cdata_nonzero(CDataObject *cd)
c/_cffi_backend.c:2114:18: warning: ‘cdataowninggc_repr’ defined but not used [-Wunused-function]
static PyObject *cdataowninggc_repr(CDataObject *cd)
c/_cffi_backend.c:1970:13: warning: ‘cdatagcp_dealloc’ defined but not used [-Wunused-function]
static void cdatagcp_dealloc(CDataObject_gcp *cd)
c/_cffi_backend.c:1961:13: warning: ‘cdatagcp_finalize’ defined but not used [-Wunused-function]
static void cdatagcp_finalize(CDataObject_gcp *cd)
c/_cffi_backend.c:1899:12: warning: ‘cdataowninggc_clear’ defined but not used [-Wunused-function]
static int cdataowninggc_clear(CDataObject *cd)
c/_cffi_backend.c:1852:13: warning: ‘cdataowninggc_dealloc’ defined but not used [-Wunused-function]
static void cdataowninggc_dealloc(CDataObject *cd)
c/_cffi_backend.c:1829:13: warning: ‘cdataowning_dealloc’ defined but not used [-Wunused-function]
static void cdataowning_dealloc(CDataObject *cd)
c/_cffi_backend.c:1783:1: warning: ‘get_alignment’ defined but not used [-Wunused-function]
get_alignment(CTypeDescrObject *ct)
c/_cffi_backend.c:1127:1: warning: ‘convert_to_object_bitfield’ defined but not used [-Wunused-function]
convert_to_object_bitfield(char *data, CFieldObject *cf)
c/_cffi_backend.c:964:1: warning: ‘write_raw_float_data’ defined but not used [-Wunused-function]
write_raw_float_data(char *target, double source, int size)
c/_cffi_backend.c:710:20: warning: ‘cfield_members’ defined but not used [-Wunused-variable]
static PyMemberDef cfield_members[] = {
c/_cffi_backend.c:701:1: warning: ‘cfield_dealloc’ defined but not used [-Wunused-function]
cfield_dealloc(CFieldObject *cf)
c/_cffi_backend.c:647:20: warning: ‘ctypedescr_methods’ defined but not used [-Wunused-variable]
static PyMethodDef ctypedescr_methods[] = {
c/_cffi_backend.c:604:20: warning: ‘ctypedescr_getsets’ defined but not used [-Wunused-variable]
static PyGetSetDef ctypedescr_getsets[] = {
c/_cffi_backend.c:594:18: warning: ‘ctypeget_relements’ defined but not used [-Wunused-function]
static PyObject *ctypeget_relements(CTypeDescrObject *ct, void *context)
c/_cffi_backend.c:584:18: warning: ‘ctypeget_elements’ defined but not used [-Wunused-function]
static PyObject *ctypeget_elements(CTypeDescrObject *ct, void *context)
c/_cffi_backend.c:574:18: warning: ‘ctypeget_abi’ defined but not used [-Wunused-function]
static PyObject *ctypeget_abi(CTypeDescrObject *ct, void *context)
c/_cffi_backend.c:564:18: warning: ‘ctypeget_ellipsis’ defined but not used [-Wunused-function]
static PyObject *ctypeget_ellipsis(CTypeDescrObject *ct, void *context)
c/_cffi_backend.c:554:18: warning: ‘ctypeget_result’ defined but not used [-Wunused-function]
static PyObject *ctypeget_result(CTypeDescrObject *ct, void *context)
c/_cffi_backend.c:545:18: warning: ‘ctypeget_args’ defined but not used [-Wunused-function]
static PyObject *ctypeget_args(CTypeDescrObject *ct, void *context)
c/_cffi_backend.c:513:18: warning: ‘ctypeget_fields’ defined but not used [-Wunused-function]
static PyObject *ctypeget_fields(CTypeDescrObject *ct, void *context)
c/_cffi_backend.c:488:18: warning: ‘ctypeget_length’ defined but not used [-Wunused-function]
static PyObject *ctypeget_length(CTypeDescrObject *ct, void *context)
c/_cffi_backend.c:479:18: warning: ‘ctypeget_item’ defined but not used [-Wunused-function]
static PyObject *ctypeget_item(CTypeDescrObject *ct, void *context)
c/_cffi_backend.c:474:18: warning: ‘ctypeget_cname’ defined but not used [-Wunused-function]
static PyObject *ctypeget_cname(CTypeDescrObject *ct, void *context)
c/_cffi_backend.c:441:18: warning: ‘ctypeget_kind’ defined but not used [-Wunused-function]
static PyObject *ctypeget_kind(CTypeDescrObject *ct, void *context)
c/_cffi_backend.c:427:1: warning: ‘ctypedescr_clear’ defined but not used [-Wunused-function]
ctypedescr_clear(CTypeDescrObject *ct)
c/_cffi_backend.c:397:1: warning: ‘ctypedescr_dealloc’ defined but not used [-Wunused-function]
ctypedescr_dealloc(CTypeDescrObject *ct)
c/_cffi_backend.c:391:1: warning: ‘ctypedescr_repr’ defined but not used [-Wunused-function]
ctypedescr_repr(CTypeDescrObject *ct)
c/_cffi_backend.c:341:31: warning: ‘default_allocator’ defined but not used [-Wunused-const-variable=]
static const cffi_allocator_t default_allocator = { NULL, NULL, 0 };
In file included from c/_cffi_backend.c:323:
c/minibuffer.h:157:1: warning: ‘mb_clear’ defined but not used [-Wunused-function]
mb_clear(MiniBufferObj *ob)
c/minibuffer.h:140:1: warning: ‘mb_dealloc’ defined but not used [-Wunused-function]
mb_dealloc(MiniBufferObj *ob)
c/minibuffer.h:128:22: warning: ‘mb_as_buffer’ defined but not used [-Wunused-variable]
static PyBufferProcs mb_as_buffer = {
c/minibuffer.h:118:26: warning: ‘mb_as_sequence’ defined but not used [-Wunused-variable]
static PySequenceMethods mb_as_sequence = {
c/minibuffer.h:102:18: warning: ‘mb_str’ defined but not used [-Wunused-function]
static PyObject *mb_str(MiniBufferObj *self)
c/minibuffer.h:16:19: warning: ‘mb_length’ defined but not used [-Wunused-function]
static Py_ssize_t mb_length(MiniBufferObj *self)
In file included from c/_cffi_backend.c:320:
c/misc_thread_posix.h:40:27: warning: ‘get_cffi_tls’ defined but not used [-Wunused-function]
static struct cffi_tls_s *get_cffi_tls(void)
In file included from c/misc_thread_posix.h:17,
c/misc_thread_common.h:142:1: warning: ‘thread_canary_free_zombies’ defined but not used [-Wunused-function]
thread_canary_free_zombies(void)
c/misc_thread_common.h:98:1: warning: ‘thread_canary_dealloc’ defined but not used [-Wunused-function]
thread_canary_dealloc(ThreadCanaryObj *ob)
c/misc_thread_common.h:222:21: warning: ‘ThreadCanary_Type’ defined but not used [-Wunused-variable]
static PyTypeObject ThreadCanary_Type = {
In file included from c/_cffi_backend.c:92:
c/malloc_closure.h:166:21: warning: ‘cffi_closure_alloc’ defined but not used [-Wunused-function]
static ffi_closure *cffi_closure_alloc(void)
error: command ‘arm-linux-gnueabihf-gcc’ failed with exit status 1
ERROR: Command errored out with exit status 1: /home/pi/klippy-env/bin/python2 -u -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-RqNfG3/cffi/setup.py’"’"’; file=’"’"’/tmp/pip-install-RqNfG3/cffi/setup.py’"’"’;f=getattr(tokenize, ‘"’"‘open’"’"’, open)(file);code=f.read().replace(’"’"’\r\n’"’"’, ‘"’"’\n’"’"’);f.close();exec(compile(code, file, ‘"’"‘exec’"’"’))’ install --record /tmp/pip-record-CfpR0V/install-record.txt --single-version-externally-managed --compile --install-headers /home/pi/klippy-env/include/site/python2.7/cffi Check the logs for full command output.
please help
