Issue with SKR Pico v1.0 / Invalid oid type & Timer too close
MCU / Printerboard: SKR Pico v1.0 (UART or USB) + SKR MINI E3 V3 (USB) + BTT Eddy (USB)
Host / SBC: BTT PI v1.2, tested on BTT image V2.3.4 and v3.0
klippy_usb.log: SKR Pico connected via USB and installed on top of RPI. Cooler blowing on Pico. BTT PI using image V2.3.4 with klipper preinstalled
klippy_uart.zip (1.3 MB)
klippy_uart.log : SKR Pico connected via UART and installed on top of RPI. Cooler blowing on Pico. BTT PI using image V3.0 with klipper preinstalled
klippy_uart+fan.zip (4.3 MB)
klippy_uart+fan.log : SKR Pico via UART and installed next to RPI. Added 3rd cooler blowing on RPI. BTT PI using image V3.0 with klipper preinstalled
Hello all,
I have an issue with configuration described above.
Pico gets disconnected when I`m doing such steps:
G28
_CLIENT_LINEAR_MOVE Z=200 F=600 ABSOLUTE=1
M84
G28
G29
It happens not all the time, but on 3rd-4th try.
Eddy configured to do mesh 200x200 specially to make load on RPI CPU, as I thought about shutting down after 54 degrees.
First issue randomly happened when Pico was connected by USB: Timeout with MCU ‘pico’ . RPI was connected to power-adapter via 24V
I tried to switch to UART: MCU ‘pico’ shutdown: Invalid oid type. RPI takes power from UART / PICO
Last try separated PICO from RPI and added 3rd cooler: MCU ‘pico’ shutdown: Timer too close. RPI takes power from UART / PICO and cable changed.
I measured Voltage on power-source - 24V no matter what I`m doing: heating the bed, nozzle and homing at the same time.
Please give an advice what else to check.
Thank you in advance,
klippy_usb.log, as only 2 files can be attached to one message
klippy_usb.log (899.3 KB)
Unfortunately, it is not clear what is happening. All looks like some hardware issues with the Pico.
Could be an effect of the excessive mesh.
seems so…
I changed RPI, changed Flash and newly installed os, changed screen, gave power from laboratory source. Only left is Pico…
Will try to move z-motors from Pico to SKR mini E3 V3 to see if it will help. All devices are out of the box(
Switched to katapult and saw how can0 appears/disappears.
Issue with controller.
Thanks for advice about possible hardware issue!
