Klipper restarts upon setting bed temperature
Hello,
I’m running Anycubic Chiron with SKR 2 board. I’m using ODROID M1 as SBC for running Klipper. As soon as I give the target temperature to heat the bed and press enter, my printer restarts and it asks me restart firmware. It was printing fine last night and today I keep getting this problem. Please help.
klippy (2).log (4.5 MB)
When you disconnect the heated bed, does it sill restart when you try to heat up?
If not: Check the wiring and the heated bed for short circuits.
Yes, that was the problem. There was a stray wire in between the bed mosfets. Thanks.
