Klipper RPC Shim library
Shortly speaking, sometimes I think custom extensions can live outside of the Klippy/Klipper process.
Here is the API, and it should be enough for most basic stuff.
I see the Moonraker as the perfect example of a klipper extension.
This library is supposed to be used as part of the daemon/service that connects to the Klipper socket.
Declares supported functions and probably loads macros to call those methods.
Some missing pieces, for now:
  • Macros should be loaded by the external installer into the printer config.
  • The only way to communicate with the user and the UI consoles is to use RESPOND g-code.
This example should cover something; it is also available inside the repo:
from queue import Queue
from KlippyRPCShim import KlippyRPCShim
def main():
    krpc = KlippyRPCShim()
    info = {
        "method": "info",
        "params": {
            "client_info": {
                "program": "KRPC", "version": "0.0.1"
    # Register itself and test connection
    resp = krpc.query(info)
    print(f"sync response: {resp}")
    promise = krpc.query_async(info)
    print(f"async response: {promise()}")
    # Test subscription
    import statistics
    request = {"method": "adxl345/dump_adxl345", "params": {"sensor": "adxl345"}}
    pkgs = 5
    generator, cancel = krpc.subscribe(request)
    for resp in generator():
        params = resp.get("params")
        if params is None:
            continue
        d = params["data"]
        val = [row[1] for row in d]
        # Compute mean and standard deviation
        mean_val = statistics.mean(val)
        stddev_val = statistics.stdev(val) if len(val) > 1 else 0.0
        print(f"Mean value: {mean_val:.3f}, StdDev: {stddev_val:.3f}")
        pkgs -= 1
        if pkgs <= 0:
            cancel()
    params_q = Queue(1)
    krpc.register_remote_method(callback=params_q.put, remote_method="noop")
    while True:
        print(f"{params_q.get()}")
if __name__ == "__main__":
And so the call of the custom method is:
[gcode_macro NOOP]
  {action_call_remote_method("noop", frequency=300, duration=1.0)}
Probably it would be nice if Klippy would print call errors in the console of gcode is called from the console.
I think the next step would be to implement a simple server to generate calibrate_shaper graphs, as an example.
Because my initial motivation was help shake tune be less intrusive and less dependent on the Klipper internals.
Hope someone finds it useful.
-Timofey
Said, done: GitHub - nefelim4ag/KlippyResonanceGraphs: Example project to generate graphs from Klipper test resonances in the external daemon
Pure proof of concept.
Upon call of the new macro, the external daemon does all things:
  1. Move to the testing point
  2. Subscribe/store ADXL data
  3. Run resonance test
  4. Generate a graph using the existing script over stored data.
(Ah, and it stores data/graphs to the printer config directory).
Hope that helps someone.
-Timofey.
