Hey, this has probably been asked a billion times at some point but I just joined this discord. I have a couple machines running klipperscreen and I am running into the issue where I am only able to connect to the wifi that is set up when I flash the SD card. Whenever I try to use the network manager it says insufficient privilege’s. I have done some digging and found that people were having this issue on older versions and they suggested reinstalling. I have done that with the same results. I am running v0.4.6-12-gb3115f9b. If there is any insite or setting Im missing that is causing this please let me know. I would be immensely grateful.
Hello @pogo1213 !
Is that the Klipper version?
If yes, that is quite ancient. Last recent one (26-11-2025) is v0.13.0-375-gba79d72f
What SBC hardware are you running?
What distro are you running on the hardware?
I had this issue on a intel tablet running ubuntu server. Ubuntu no longer uses Network Manager as the default network interface. I don’t recall the exact steps but I had to install AND CONFIGURE network manager in Ubuntu.
I recall at one point having 3 minute boot times until I got the configuration right.
That is the KlipperScreen version; Klipper itself is v0.13.0-406-gbaf188bd
Raspberry Pi 4
