Can someone tell me why my “adjust” parameters are not working? I know jinja has some weirdness with how macros are evaluated in full before execution but I can’t figure out what the exact problem is:
[gcode_macro set_separation]
{% set svv = printer.save_variables.variables %}
{% set oldX = svv.xoffset|float %}
{% set oldY = svv.yoffset|float %}
{% set oldZ = svv.zoffset|float %}
{% if params.X is defined %}
SAVE_VARIABLE VARIABLE=xoffset VALUE={ params.X|float }
{% if params.Y is defined %}
SAVE_VARIABLE VARIABLE=yoffset VALUE={ params.Y|float }
{% if params.Z is defined %}
SAVE_VARIABLE VARIABLE=zoffset VALUE={ params.Z|float }
{% if params.X_adjust is defined %}
{% set newX = params.X_adjust|float + oldX %}
SAVE_VARIABLE VARIABLE=xoffset VALUE={ newX|float }
{% if params.Y_adjust is defined %}
{% set newY = params.Y_adjust|float + oldY %}
SAVE_VARIABLE VARIABLE=yoffset VALUE={ newY|float }
{% if params.Z_adjust is defined %}
{% set newZ = params.Z_adjust|float + oldZ %}
SAVE_VARIABLE VARIABLE=yoffset VALUE={ newZ|float }
