Macro that reacts to a thermistor temperature?
Printer Model: RatRig Vcore 3.2h
MCU / Printerboard: Octopus max ez
Host / SBC: rpi4
hi,
not an issue…
It’s summer where I live, and the overtemperature problems have returned…
I finally installed thermistors on the drivers, which give me real-time temperature information. I know the temperature the sensors read is NOT the driver’s temperature, but it’s valuable information nonetheless.
and I can see it in real time in FluidD.
I was wondering if it would be possible to add a macro, or something similar, so that when the sensor temperature reaches a certain value, either the motor current decreases, or the speed factor changes, for example, to 40%. Even if the temperature drops, it could at least increase again, but at least bring it down.
Could this be done with Klipper? A macro that runs if a temperature sensor reaches a certain value?
It’s almost certainly possible. But I don’t believe that that is the correct approach.
This is from a thread when I was trying to understand overtemp warnings when I first encountered them, and if you look at his final point, the current will remain the same even if speed factor is reduced, so that’s out as a solution.
As far as adjusting current midprint, maybe that could work, but because using hold current ‘might’( TMC drivers - Klipper documentation ) introduce motor movement, I would expect that approach ‘might’ as well and you may lose accuracy in your prints.
I would think the best approach to solving this issue would be to add additional cooling for the drivers, or simply find a lower run current you can be satisfied with.
